Error code software?
Old May 25, 2011 | 10:36 PM
jesredvette's Avatar
jesredvette
Default Error code software?
Does anyone know if there is any software available that I can get to hook up to my '88 (OBD1) and read error codes on a laptop?
Old May 25, 2011 | 11:33 PM
John A. Marker's Avatar
John A. Marker
There are code readers on the market, but they will give you the error code and perhaps a brief statement as to the code. An advantage to a reader (a good one) is that many will data log for you. If you do a search in the Scan & Tune Section you will probably find reference to software that is out there for you application.
You can use the paper clip method for the cost of a paper clip.
Old May 26, 2011 | 12:55 PM
george4's Avatar
george4
Another fan of the paper clip method here.
http://www.corvettebuyers.com/c4vettes/ecm.htm
Old May 26, 2011 | 01:25 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I like TunerPro. Download is free. ALDL cable from ALDLCABLE.com completes the toolset. http://www.aldlcable.com/sc/details.asp?item=aldlobd1u
With this, you can scan codes, do scan logs, set TPS/IAC, and help diagnose other problems.
Old May 27, 2011 | 03:26 PM
3D87C4's Avatar
3D87C4
http://www.ttspowersystems.com/DataMaster.html is another option
Old May 27, 2011 | 09:35 PM
viii's Avatar
viii
Here is one I collected from the forum http://winaldl.joby.se/
To Error code software?
