Lean idle misfire
Old May 30, 2011 | 11:29 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Lean idle misfire
OK, egr was changed old one was shot, no vacuum leaks, fairly new plugs & wires all tight and injectors good. Could this be coil or ICM?
Old May 31, 2011 | 11:11 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
How do you know its lean? Can you tell what cylinder is misfiring?
Old May 31, 2011 | 07:13 PM
ex-x-fire's Avatar
ex-x-fire
Try adding alittle propane through the pcv valve, if it smooths out any then you probably have dirty injectors. Have them cleaned, if you have em cleaned on the car make sure they do a double dose, meaning running on 2 cans of cleaner instead of one.
To Lean idle misfire
