AC/Temps/Oil Pressure
Since you don't know if your Display is accurate, I'd start by comparing the Coolant to the Coolant Temp Sensor with a Scanner. They should be within a couple of degrees. I would also replace the ECM as a full time fan doesn't work as well as one that cycles.
A/c operation results in lower coolant temps as the fan is on sooner and runs longer. It needs to because you don't make cold air without keeping what's going on in the Condensor at a considerably lower temp than the what's going on in the Radiator. That's why the Condensor is in front and that's another reason why the coolant temperature is controlled by a thermostat. Since your Vette's Main Cooling Fan is a full time affair (though above 40 mph it's probably impeding air flow), the coolant shouldn't be heating up with the a/c on and that's either a crapped out cooling system (compressor load overwhelms a partially plugged up radiator, bad shroud, missing front spoil, etc) or a plugged up a/c system. Start by checking it's a/c operating pressures. The high side should average about 200 psi and that's normally controlled with the Main Fan cycling on/off between 190 and 230 psi. Check those pressures with a Manifold Gage Set. Running the fan full time will drop the high side too low and that means the compressor is going to cycle which increases wear (and because it's engagement isn't controlled by the ECM for your Year, it can also cause minor idle issues; ie, most of these Years "feel" compressor engagement - better to just keep it running and it does that really well with the fan cycling on/off).
The Aux fan isn't necessary for a/c and isn't linked to it. It was initially a Dealer installed option following complaints from racers and high altitude users. There was extensive hot weather testing of the Vette and a Vette with the single fan was able to maintain appropriate cooling with or without the a/c blasting. Return it to the way it left the Factory and it'll be fine.
My 57 Chevy pickup has a 1980 4 bolt main truck block, and with 5W30 oil, the lifters make noise. With 10W30, the noise is gone. Oil pressure is up about 7 PSI.
Your engine is of the same factory machining tolerances as my truck engine. I would jack up the oil weight a notch in the summer, and thin it out in the winter.
You can remove the air filter and the top of the radiator shroud, and clean out the air cavity between the radiator and the condensor.
Also, on my 86, I wired the main fan power wire to the coil of an auxiliary fan relay, and when the computer calls for the fan, there is more fan capacity than original, and it cools down quickly.
Just a note,
The dealer option will be really expensive. Nobody there knows your car even as well as you do. I would hunt down a corvette mechanic somewhere near where you live. Buy a service manual for your car, and you will discover how easy it is to move the wires back and restore the fan operation.
You can do it easy. The ECM has 2 connectors and plugs in with a "snap". your kid could do it.
Also, with the fan wired on all the time, the engine takes a long time to warm up. That will cause more damage than heat.
Just a note,
Thanks again to all of you. I always feel bad that I don't have the ability to help someone as the folks on the forum have helped me. One of the real bonuses I have found by getting my Corvette is that fellow owners here aren't just nice people, they represent more than that. It kind of like family. Pretty danged cool.
