Fuel Injector question testing
Old Jun 1, 2011 | 02:50 PM
Repzard's Avatar
Repzard
Default Fuel Injector question testing
Hello forum.
I have a 93 Corvette with stock LT1.
When car gets hot (warmed up) the car has a slight miss or popping sound in exhaust that you can hear.
So far i have replaced the Spark plugs,Wires and ICM (All OEM ) and last coil with MSD street fire. and still have this miss.
So now I test ohms tested the fuel injectors and they all tested at 12.5 ohms cold.
I read that they should test at 16 ohms or better.
Does 12.5 seem low and this could be the problem causing miss?
I heard if its a optispark problem it would be running rough at start up and pretty much all the time.
Thanks for any help
Repzard
Old Jun 1, 2011 | 03:10 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It depends on which injectors you have. 12.5 is still considered a high impedance injector. Check them hot and cold and if they are consistent with each other within each heat range they are probably OK.
Old Jun 1, 2011 | 03:30 PM
Muffin's Avatar
Muffin
Not an LT1 guy but agree with BADDuck, injectors should be checked hot and cold. Something to think about: Only when warm, is something happening when the system goes into closed loop? Sounds like it. Have you attempted to pull codes? Can you have a scan run to document changes?
Old Jun 1, 2011 | 03:59 PM
mckinpe21's Avatar
mckinpe21
If it helps, I HAD the same exact problem. It even blew the Injector 2 fuse. I too changed the optispark (due), Plugs, and wires. I checked the other known suspects. It turned out I had one injector testing really really low.
How did your plugs look? I ended up changing to the Bosch III, and the car feels new again
But what prompted my response was a slight miss, and a slight popping at idle in the right exhaust bank.
Hope that helps.
Old Jun 1, 2011 | 04:19 PM
Repzard's Avatar
Repzard
Well I just tested them hot all injectors test at 12-13 ohms except for 1 tested 10.2 ohms (last injector on pass side toward fire wall ) so I think I may have found the issue.
1 bad injector .???
Ps..did check codes..none just 12
So I think i will be ordering some Bosch III
Old Jun 1, 2011 | 04:34 PM
BADDUCK's Avatar
BADDUCK
Why not just replace that one injector? Why replace 7 good ones?
Old Jun 1, 2011 | 04:39 PM
Repzard's Avatar
Repzard
Is it okay to just replace 1 ?
It sure is cheaper
Old Jun 1, 2011 | 04:47 PM
BADDUCK's Avatar
BADDUCK
Sure, you just need a part # and shop around.
Old Jun 1, 2011 | 04:49 PM
Repzard's Avatar
Repzard
okay...TY BADDUCK
Old Jun 1, 2011 | 05:06 PM
samsonb's Avatar
samsonb
It sure is cheaper
You probably have the bad Multec injectors since yours is a 93. So, I'd recommend to replace them all.
Old Jun 1, 2011 | 05:11 PM
toptechx6's Avatar
toptechx6
The GM part number is 17015094, but it comes up as discontinued. Rock Auto shows several brands but a single new one (not remanufactured) is almost half the cost of a set of 8 Bosch III's from Jon at FIC.
Your call of course, but I know what I would choose.
Old Jun 1, 2011 | 05:23 PM
BADDUCK's Avatar
BADDUCK
okay...TY BADDUCK
Injector Warehouse has your injector for $34.95. You may do better if you shop around (less work too).
Old Jun 1, 2011 | 06:12 PM
aklim's Avatar
aklim
It sure is cheaper
You can in a pinch but I wouldn't. While they are out, have them sent in for cleaning and testing. That way you know all are flowing at the same rate.
Old Jun 1, 2011 | 06:51 PM
Repzard's Avatar
Repzard
Update: Well i called up Jon @ F.I.C and left a message.
These are the injectors im looking at to buy. http://fuelinjectorconnection.com/sh...&productId=197
If Jon say they will be fine..Its a sale
I want to Thank "ALL" for your input and help , again the forum comes to the rescue
Old Jun 1, 2011 | 08:37 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
The Bosch 3's are very good. And Jon is d'man for injectors.
Old Jun 1, 2011 | 10:17 PM
jfb's Avatar
jfb
An ohmeter will only find gross injector coil failures. The defining electrical test for injector coils can be done with an imedance bridge which measures the coil inductance and Q. I had a bad injector in my 87 which measured the same d.c. resistance as all the other injectors but my impedance bridge showed 1/2 the inductance and 1/2 the Q. An ohmeter will not find a turn to turn short in the coil, but an impedance bridge will easily find this fault.
Old Jun 1, 2011 | 10:30 PM
87 vette 81 big girl's Avatar
You have to explain what an Impedance Bridge is to others here on C4(show a picture.)
I know what it is.
My father has one for Antique vacuum tube radio repair in his basement workshop.
He uses it for the IF cans & " Litz wire wound oscillator coils.
You are an Electrical Engineer I know.
BR
To Fuel Injector question testing
Old Jun 1, 2011 | 10:43 PM
jfb's Avatar
jfb
I know what it is.
BR
I guess I should, but I doubt anyone is going to buy an impedance bridge to test their injectors. I have been thinking about showing how to make a simple impedance bridge yourself, but even simple ones require an audio oscillator circuit and headphones.
Old Jun 1, 2011 | 10:44 PM
aklim's Avatar
aklim
I never have ohmed my injectors. I figure that they can figure it out when it is being cleaned and tested. Even if you had an impedance bridge and even if it said the injector coil is A-OK, what is the point? It doesn't tell you what the condition of the rest of the injector is. On my other car, I had 5 good injectors and one dirty one. This is why I send my injectors off every few years for cleaning and testing. Sure, you can check it out electrically but that is not a very through test.
Old Jun 1, 2011 | 10:50 PM
Like I said a few months before,
My father would "Kill" if I took his Impedance Bridge and claimed it as my own.
LOL
My temper came from somewhere.
I appreciate your input & vast electrical experience always here on C4.
Brian
