stock L98 top end performance woes
34MPH
4275 RPM
4.04 v TPS
95.9 GPS Maf
8.75 ms PW
125 BLM
128 INT
910.2 mv o2
85 crosses
143 LV
4275 RPM is at the point where the car goes no faster. Everything here seems good except MAF flow. I am getting excited as I come closer to fixing this, looks like I am getting about half the airflow I need and the car runs pretty strong. I will post the results of my base engine check soon. Thanks!
Keep us informed.
Dave
Now that wide bands are used with modern electronics we can get much closer to 14.7 and maintain it(and make power with it), but things have come along way in the past 15 to 25 years.
In the business I am in now we run wide bands from the manufacturer, and can take advantage of the increased flexibility of compression, boost , aggressive spark curves with out the threat of damage.
Without widebands and FAST(not the company,the speed) electronics we wouldnt have direct injection, because we couldnt run it reliably.
Very interesting conversation, I am enjoying it!! Hopefully we can all brainstorm and get this thing fixed!!
Dave
Yep.
(pw-load) and I will do a scan, also. Keep in mind that there is something wrong with my car (and I don't think it is my tune) so it could be affecting the scan.
27mph vehicle speed
3550 RPM
4.65v TPS
159f coolant temp (does not seem right.....says about 185 in cockpit)
100f MAT
98.3 gms/sec Maf
5.91ms injector
145 BLM
128 INT
888mv o2
85 crosses 02
142 Load v
closed loop
I think this was a first gear stab on the on ramp....keep in mind that the pins are jumped during a scan on my car.
I have posted in scan and tune with little response. My car has no power over 4k and will not rev past 4300 rpm. Closed loop scans look great. MAF grams/sec never exceed 105. I am leaving a lot of power on the table here, obviously. 2 different chips, similar results. New fuel pump, filters. New injectors 19lb tuned with fuel pressure (44lb) and injector PW, similar results. Gutted cat with res tips. New ICM and coil. The car does nothing dramatic, idles great, excellent throttle response, just runs out of breathe. TPS has full range.
I am very new to scans and could use some help and ideas. The MAF topping at 105 is a big red flag to me. I think the MAF is fine, it is just measuring the actual air flow. I need some ideas and thanks in advance. Oh....i have the 85 870 ecm. I am not changing it, unless it is bad.
Thats the problem !
as the ecm tried to compensate by widening the inj pulse to its maximun, the scan shows O2 too rich because of the wide inj pulse width...not because there is actually a rich condition...the ECM THINKS there is because it THINKS there are 22 lb inj running with the broad fuel pulse.....
bOTTON LINE, WHEN YOU STARVE IT FOR FUEL the scans will show it rich because the ECM is compensating its *** off and its not getting results, so it knows its sending too much fuel, so it shows as rich when its actually LEAN as it can get...The ECM reads the response of controls, like the fuel inj signal....not what is coming out of it. Thats gonna be lean as hell and confuse the O2 even more.
wrong theroy with the fuel inj......you can get bigger inj and dial down the pressure to have less, but you cannot buy small inj and run high pressure to get more. If its a 19 lb, that is ALL it can possible do.
Go find some 24lb/hr and run then at around 35-38lb/hr and it will run fine. Check the spark plug color after a run to confirm the color of the inner insulator. The open exhaust is begging for more fuel...not less. If there was ANY intake work done.....go up another step.
19lb ? seriously?
Problem solved.
19lb ? seriously?
Problem solved.
I have often wondered if switching back to the 24 pounders would be the fix. I have a set on the shelf. But I have yet to be convinced. Edit: There are lots of people running 19 # injectors in 350's on ThirdGen...the Ford Yellowtops are rated 19# at 39 psi (22# at 43.5) I am pretty sure they will run a 350 over 4300 rpms.
vac blocked) I also hooked a DVM to the signal wire on the MAF. Most I got out of it was 3 volts. I think it is reading correctly....just no air to read.
You said you have no RPM rise after about 4300 RPMS. is this only under load? In every gear? Go out and run again WOT at 4k rpms, and see if you can get the vacuum gauge to climb up at all. You will not get idle vacuum but you should get something.
Another thing you may want to do is a plug check,what does it look like.
Dave
At wide open throttle around 3.75 volts(ish) tp the processor starts going after a table, it does not care where the O2 is . And it does not adjust on the fly within reason. When you are looking at the O2 , you are just looking at the voltage it is making, That reading is not manipulted by the PCM, it is an input to the PCM.
Your biggest problem, and what everybody keeps looking past is the MAF gps. It is also an input to the processor, and it is telling the processor I AM NOT FLOWING MUCH AIR. The processor is going to tailor fuel rate to that.
Are you leaning out , possibly, is that the reason you are not getting RPM, probably not.
Again, make sure your base engine is correct, or you will chase your tail.
I would change the coolant temp sender that sends coolant temp to the computer, then scan it again and see if the computer and the dash gauge match.
Another thing, the 1985 TPI is all by itself. The 85 has a MAF module. The maf module can possibly be modifying the MAF signal to the ECM, and tell it an eroneous air flow. THat can limit your fuel if the ECM thinks the MAF is flowing less than it really is.
Another thing, make sure the previous owner did not disconnect the knock sender and install a resistor to keep the ECM from seeing any knock counts. With 19 Lb injectors, I would expect a lean condition at WOT. With 19 Lb injectors, I would guess that you would see fuel normal until about 4000-4500 RPM, and then start leaning out as the injectors are maxed out as engine RPM increases...to a point where the engine is RPM limited based on fuel suply
I believe the coolant temp that ecm sees is a different sensor than the coolant sensor for the dash, you are looking at 2 different readings, I can double check that.
The MAF module is a burn off module, it does not affect the readings to the ECM, I have a picture of the schematic for the module, and the signal goes directly from the MAF to the ECM, the module only is in control of burn off.
I have an idea, I am not sure if it will work. Try disconnecting the MAF entirely, and see if you can drive the car. You will be in FMEM, and will be running on set tables.(Limp) see if you can get more than 4k then. It may not even run well enough to do it, but it's worth a try.
With the way you have described your vacuum at WOT, I think you have the answer.
I have not ruled out the MAF. I hooked a DVM to the sig wire, and could not get it over 3v driving the car to redline. It may be reading the air or malfunctioning. I suppose it should go to 5v? Any ideas on how to make sure my MAF is good? Maybe I can find a way to blow some air on the wire...hmmm. It worked great before the rebuild. It has been cleaned.
Funny you should mention the knock sensor. The wiring was bad and it did not work. Much pinging...I fixed it right away and have not heard a knock since. My ALDL does not show knock counts....could the ESC retard the timing enough to RPM limit the engine? Detonation mostly occurs at low rpm(low vacuum)/high load conditions. My car runs great under these conditions.
I am still seeing(hearing) it both ways on the 19# injector thing. I still do not understand how increasing the FP and upping the pulse width to a reasonable (or unreasonable) duty cycle cannot work properly on a 350 making 275 HP on its best day. It has not had its best day yet, I think it is making no more than 200 hp. I am going to try unhooking the MAF.
He was telling me that the car should go into open loop at wot, he has seen this before and it is generally because the tp is not showing wot.
From the looks of your scan that is not the case,but he did say to keep a close eye on tp voltage, and make sure it is clean voltage, not jumping around, you may want to sweep it manually with a meter to make sure.
He also told me to make absolutely sure your lifters are adjusted correctly, and not pumping up from being over tightened(which will kill topend power).
Just passing this along, hope it helps.
The open loop in WOT thing is how I started this thread. My scans clearly show that the system is in closed loop at all times after initial warmup. Someone suggested this was correct. I need to confirm that the computer should acknowledge (on the scan), going open loop above a certain TPS voltage. I will play with the TPS and DVM right away.
As far as the valves being too tight....they have been set 2 different times. I set them a 1/2 turn past zero lash. I would love it if this was my problem. I may try 1/4.
Now the vac gauge thing......I did some studying up. I believe that the vac gauge is showing what the MAF is showing......that there is no air. The symptoms of no recovery after mashing the throttle open are symptoms of low compression. I will do a compression check ASAP (probably one of the first things I should have done). The needle was always rock steady, meaning this is a problem shared with all cylinders, so it is not a broken ring or a bad valve. It also seems to confirm that my cam timing is OK. My car uses no oil, the plugs look good, and it doesn't smoke.
Once again....thanks. And I would love for someone to chime in about the open loop thing.
