Pwr steering pulley
Old Jun 4, 2011 | 11:58 AM
Tom 35th anniversary's Avatar
Default Pwr steering pulley
Quick question so I done screw up. Is the power steering pulley just pressed on the shaft of the pump? Do I just use a 2 or 3 point claw puller to remove it? Just trying to avoid unnecessary damage...
Old Jun 4, 2011 | 01:38 PM
TWISTERUP's Avatar
TWISTERUP
There is a special PS pump pulley puller, it has a lot more jaw/gripping surface then a typical 2 or 3 jaw puller. They can be a real PIA with the correct puller IMO. You might try some of the parts stores in your area, some of them rent specialty tools.
Old Jun 4, 2011 | 02:02 PM
ex-x-fire's Avatar
ex-x-fire
The p/s pulley puller pulls on the center of the pulley, using a puller that hooks to the outside of the pulley will bend it.
Old Jun 4, 2011 | 02:13 PM
Thanks guys, glad I asked. Rented one from auto zone. Came off very easily. One of the easier jobs ive had to do on this car. Might as well replace the pressure side hose while im at it...couldnt get to the fittings when its back together!!!!!
To Pwr steering pulley
