4+3 reverse lift-up ring question
Old Jun 4, 2011 | 09:23 PM
AustinJohn's Avatar
AustinJohn
Default 4+3 reverse lift-up ring question
I've just replaced the reverse lockout rod in my '85 and when I shift into reverse the lift-up ring stays "up" whereas before I believe it returned to the "down" position. How does it work on your 4+3?
Many thanks!
John
Old Jun 4, 2011 | 10:20 PM
powerpigz-51's Avatar
powerpigz-51
I am pretty sure mine had a spring on it somewhere........
Old Jun 4, 2011 | 10:25 PM
VB Racing's Avatar
VB Racing
There should be spring between the ring and the shift ****, pretty big one at that. I just had mine apart.
Dave
Old Jun 5, 2011 | 06:12 AM
AustinJohn's Avatar
AustinJohn
Thanks powerpigz-51 and VB Racing.
Mine has the spring. What I'm asking is in all other gears the reverse ring goes "down" against the stop on shaft but in reverse after pulling the ring "up" to get into reverse, the ring stays "up" and won't go "down" until moved out of reverse. Is that how yours works?
John
Old Jun 5, 2011 | 01:04 PM
VB Racing's Avatar
VB Racing
John
yep, that's correct, it just keeps you from shifting into reverse accidentally.
Old Jun 5, 2011 | 01:07 PM
AustinJohn's Avatar
AustinJohn
Thanks a million!
John
Old Jun 5, 2011 | 07:46 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I have a good used '85 4+3 shifter for $65, with link arms, $100
Old Jun 5, 2011 | 07:56 PM
AustinJohn's Avatar
AustinJohn
Does it have the **** and button? If so, I'll take the package with link arms. PayPal?
Thanks! John
Old Jun 6, 2011 | 01:07 AM
coupeguy2001
85 has no button..........but it has the ****
Old Jun 6, 2011 | 03:01 AM
XPLOSV's Avatar
XPLOSV
Many thanks!
John
Why do they call it a 4+3 ?
Old Jun 6, 2011 | 03:05 AM
AustinJohn's Avatar
AustinJohn
Thanks for getting back to me. Unfortunately mine is a late '85 with the button on the shifter. John
Old Jun 6, 2011 | 03:13 AM
AustinJohn's Avatar
AustinJohn
Doug Nash was a dragster designer/driver in the 50's and 60's (the "Bronco Buster"). He built a 5 speed transmission for dragsters that was very popular and then came up with the idea of adding an overdrive unit behind the original 4 speed in Jeeps that would add overdrive to the top three gears ("4+3"), a total of seven gears, very useful (and popular) with off-roaders.
When GM designed the C4 in the late '70's/early '80's they were scared to death of having to pay the Gas Guzzler Tax passed in 1978 during the first oil shortage. Somehow GM engineers heard about Nash's 4+3, went to the Doug Nash facilities, test drove a jeep with a 4+3, realized it 1) increased the car's gas mileage and eliminated their Gas Guzzler Tax worries, 2) increased the car's top speed and 3) did both at nominal cost so they placed their order.
John
Old Jun 6, 2011 | 03:27 AM
XPLOSV's Avatar
XPLOSV
John
Old Dec 22, 2020 | 06:46 PM
Thejake's Avatar
Thejake
1st Gear
Default 4+3
Thanks a million!
John
I'm having a problem where I have to disconnect the reverse linkage from the transmission it feels like the shifter itself is being stuck in the reverse position even though you can still put it in all four forward gears if somebody would like to call me let me know thank you
Old Dec 22, 2020 | 08:58 PM
jazfe's Avatar
jazfe
There is a procedure for setting neutral on the shifter. Not a lot of fun but simple enough, just takes time. With the wear of years I bet yours is in need of re-alignment. I will have to copy it from my manual.
Sure helped my shifter after I adjusted it.
To 4+3 reverse lift-up ring question
