Replaced Head Gaskets - Huge Amounts of Smoke... HELP!
I bought an 86 with a blown head gasket(iron heads). I had the heads milled and got a valve job done, and checked for cracks.
I reassembled following all the instructions online. I had a little trouble with the distributor timing until it would start, but it eventually started and ran. Once running I had huge amounts of white smoke coming from the header and the tail pipe. I was hoping it was just smoke burning off but it kept going. After about a minute I killed it as it was very excessive at that point filling the garage to a point where I couldent see.
I am assuming this means I blew the gasket again or have a leak. There are no leaks on the exterior of the motor and I pulled the plugs and didn't see any coolent. I turned it over a few times to see if I'd have any coming out, but nada.
The oil pressure is also good.
How can I check to see if its blown again without taking it apart? I am REALLY hoping the smoke is from the previous blown gasket and just coolant/oil in the exhaust.
I really need help before I lose my mind!!!
Thank you in advance!
Lucky Kid, Roy
Lucky Kid, Roy
Just did a compression check,
1: 135
2: 135
3: 145
4: 150
5: 150
6: 160
7: 155
8: 150
Still nothing coming out of the plug holes.
Filled the radiator up a little more and everything is still dry.
I just put 5 fresh quarts of oil in, but I think I will empty it unless someone has some other suggestions.
1: 135
2: 135
3: 145
4: 150
5: 150
6: 160
7: 155
8: 150
Never checked...I was told its rare they are warped by a couple people and just crossed my fingers. I tried to find a machinests straight edge but couldn't find one in the stores.
I do have good compression which I don't think would be possible if there was a cylnder-coolant leak... Please correct me if I'm wrong!
My experiences have taught me that the decks often warp 50% or more of what the heads do.
A compression test gives you an idea of how hard the piston pumps, not so much how well it is sealing. A leakdown tester tells you how well the entire combustion chamber seals.
Your best hope right now is that the smoke is residual coolant in the exhaust pipes.
Will i risk hydrolock by running it some more? I'd like to see if I can get any residual coolant out of the exhaust, if there is any.
Any other troubleshooting steps to check for coolant?
Thanks,
Lucky Kid
Lucky Kid, Roy
Lucky Kid, Roy
I agree....if there was a previous breech of the old gasket, you could have a lot of coolant in the muffs and cat. There is some kind of chemical test that looks for exhaust gas in the coolant. I would run it awhile and keep a good eye on what your oil looks like.....maybe run a few minutes at a time. The pressure test is a good idea, If you don't have a leak anywhere else. You could pull the plugs and crank it to see if you have water in the cylinders, if you are worried about hydrolock.
Thanks guys! I ran it for about 5-10 more minutes and it cleared up. Now, the exhaust is nice and clean!
Now I just have to figure out what is drawing current when the car is off, replace the stater cable, replace the battery and it should be driveable!
We'll see if the trans works
I really appreciate the help!!!
