PROBLEMS WITH HEATER DOOR?
Old Apr 22, 2002 | 08:45 PM
~~Tin Man~~'s Avatar
~~Tin Man~~
Default PROBLEMS WITH HEATER DOOR?
I have a 89 coupe with no heat? I have repaired the control circuit board, replaced bad resistors and weak solder joint. The heater core seems ok, I know the linkage at damper door is secure. I am wondering is there a way to check the vac. line and actuator for heat flap. I have removed the heat sink and I can not see any movement at flap door. Any info. or suggestion would be cool. :mad
thanks
[Modified by ~~Tin Man~~, 12:47 AM 4/23/2002]
[Modified by ~~Tin Man~~, 12:48 AM 4/23/2002]
[Modified by ~~Tin Man~~, 2:50 AM 4/24/2002]
