Got a problem guys...
Old Apr 22, 2002 | 09:15 PM
RadPolo96's Avatar
RadPolo96
Default Got a problem guys...
My Shift indicator has been a little bit off since my converter install. As a result the other day on the highway my car was accidentally thrown in reverse going about 70-80mph. This happened because I accidentally hit it reaching over to the passenger side. Here is what happened. The car bogged hard almost as if braking...the the engine preceded to shot off like it shoud. I quickly threw it into dive as soon as I saw what happened. Then pulled over to the side of the road. I turned off the car after putting it into park. I waited for a few seconds then tried to start it. Ittook a little longer than normal but started right up. I slowly got back on highway and accelerated to see if everything was workin. Everthing seemed to be ok. Its has been a few days since then and I have only driven it once since then and it drives normally. My question is what should I do next? What have I potentially done...besides uterly destroy my tranny? Need help!!!
Never try this in your car...VERY BAD IDEA. Scared the poop outa me.
Old Apr 22, 2002 | 09:27 PM
VetteNoob's Avatar
VetteNoob
Default Re: Got a problem guys... (RadPolo96)
Hey bud, you could have the fluid and filter changed out in case you burned it or created some metal shavings. If you really feel like spending some money, take it to Alamo and have them check out the tranny.
Old Apr 22, 2002 | 09:30 PM
RadPolo96's Avatar
RadPolo96
Default Re: Got a problem guys... (VetteNoob)
My bro has a hook up at a dealership...he is gunna see if he can get it looked at for free
Old Apr 23, 2002 | 12:08 PM
RadPolo96's Avatar
RadPolo96
Does anybody have any other suggestions?
Old Apr 23, 2002 | 02:11 PM
RadPolo96's Avatar
RadPolo96
Ok now I am startin to have problems. If I run the air conditioner and then turn it off, the car just dies. I figured I must have burnt something out. What could it be?
Old Apr 23, 2002 | 06:04 PM
VetteNoob's Avatar
VetteNoob
Im planning on a trip to Lockhart either Friday or Saturday to get my tranny checked out by that guy who smoked me on 360. Come along and Im sure he can give you an opinion for free or you can give him a call. His name is Rick and he is one of the shop foreman at AAMCO on Burnett and 183. He has a HP shop in Lockhart that does HP work called Mike's Automotive.
Old Apr 23, 2002 | 06:23 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
First question, how did it accidentally go in reverse? Were you manually shifting or did it do it on it's own?
You shouldn't be able to go into reverse without pushing the button in on the shifter.
You can go reverse to neutral without pressing the button(I think) neutral to overdrive without pushing the button and once you push the button for drive, you can just slide the shifter into 2 or 1 without using the button. Same for the way up, 1-2, 2-D, and D-OD without pushing the button.
If it shifted onits own, I have no clue.
Old Apr 23, 2002 | 06:37 PM
RadPolo96's Avatar
RadPolo96
Default Re: Got a problem guys... (Mr Mojo)
Mojo, as stated in the first part my shift indicator is off and does not lock properly in Overdrive. It locks..but only backwards...so the stick can still move forward without button.
Old Apr 23, 2002 | 06:40 PM
Mr Mojo's Avatar
Mr Mojo
Oh, I see said the blind man. :jester
Old Apr 24, 2002 | 03:21 PM
RadPolo96's Avatar
RadPolo96
Well, took it to the dealer today. They ran a diagnostics check and they said that I had a bfried IAC Valve. They said that they are 90% sure a new one will fix the problem. Got any opinions on what I should do. They say that it will cost around 200+ for parts and labor.
Old Apr 24, 2002 | 03:38 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
An IAC motor on the throttle body is ~$60 and it should not take more than 10-15 minutes to replace it. The only thing is controls is idle air entering the motor so that would make sense why the car died. I would just get the part from Jeff Kopp and fix it myself.
Old Apr 24, 2002 | 09:19 PM
Raysur's Avatar
Raysur
Default Re: Got a problem guys... (Vette92)
$200 is a rip off. You can do it way cheaper than that. I replaced mine for way less.
Old Apr 24, 2002 | 09:30 PM
ralexand's Avatar
ralexand
Default Re: Got a problem guys... (Raysur)
The Delco IAC is available locally from A-Line. I bought one in Round Rock a week ago... around $65...
Old Apr 25, 2002 | 01:39 PM
RadPolo96's Avatar
RadPolo96
Looks like I may have fixed the problem without getting a new IAC Valve. I went through the reset process for the IAC valve and it ran fine. I guess the final test will be to take it out on the road and test it. Wish me luck :seeya
Old Apr 25, 2002 | 02:14 PM
RadPolo96's Avatar
RadPolo96
Well the prob is still there, guess i will have to get new part. Hope that is the prob.
To Got a problem guys...
