A ZF model question...
Old Apr 22, 2002 | 11:26 PM
T1Kilr's Avatar
T1Kilr
Default A ZF model question...
Are there multiple models of the ZF used from 89-96? I have read something about a "black tag" model used till 93 but cannot verify anything on it. Anyone have any ideas? :confused:
Old Apr 22, 2002 | 11:45 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: A ZF model question... (T1Kilr)
There are quite a few different types.
89-91 models had gears that were cut on a slightly different angle to later models (not straight cut) which makes them a little noisier and slightly stronger.
ZR1 gearboxes have a different input shaft because of the different motor.
Not sure of what significance a "black tag" car has, my guess is that it denotes one of the early boxes described above. I'm sure someone else can verify.
Two great sites for ZF info: http://www.whiteracingproducts.com/home
http://www.zfdoc.com
Old Apr 23, 2002 | 12:08 AM
ZBRA's Avatar
ZBRA
Default Re: A ZF model question... (Red 90 L98 Coupe)
'95 and '96 models don't have a reverse lockout ring around the shifter. They have a stronger spring that makes it harder to "accidentally" push it over far enough to go into reverse.
Old Apr 23, 2002 | 02:11 PM
T1Kilr's Avatar
T1Kilr
ttt
Old Apr 23, 2002 | 03:04 PM
jburnett's Avatar
jburnett
89-93 which were the "Black Tag" models I believe are rated at 450 lb/ft of torque... 94-96 are rated at 400 lb/ft. 95-96 do not have reverse lockout ring as stated above. They're ALL NOISY, though!!
-Jeb Burnett
Old Apr 23, 2002 | 03:47 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: A ZF model question... (jburnett)
Jeb has the same info I have. I will add that the final gear ratio is different as well in some models. My '92 tranny had a .50 6th gear, and my '94 tranny had a .49 6th gear. Nothing substantial by any means, but that is what was specified on the cases.
Old Apr 23, 2002 | 03:49 PM
scorp508's Avatar
scorp508
I also believe that the 'black tag' models are the only ones that have aftermarket gears being made for them to give you a different 5th and 6th gear ratio.
To A ZF model question...
