Rattling in front y pipe
Old Jun 9, 2011 | 10:18 PM
chrisd0729's Avatar
chrisd0729
Default Rattling in front y pipe
I found the noise in my exhaust that I thought was an exhaust leak. On the driver side of my front y pipe, just behind the pre cat, something is rattling inside. With the car running, I'm holding all sections of the heat shields, the o2 sensor, etc. Right there. Nothing around the pipe or touching the pipe is moving however, if you hold the pipe or heat shield, you feel the rattling that you hear in that immediate area. It almost feels like a chambered exhaust pipe when the inner chamber broke loose from the welds. Is there anything inside the Pipe in that spot?
I sprayed down the bolts there tonight and will separate the y pipe from the cats and try to look inside this weekend. Just wanted to check here first to see if ne had the same issue or ideas what it might be.
It's a 96 LT1 with 39k miles
Old Jun 9, 2011 | 10:30 PM
JackDidley's Avatar
JackDidley
Sometimes the precat cracks and rattles. It can trigger the knock sensor and make the car do wierd stuff.
Old Jun 9, 2011 | 10:31 PM
muzikmanwi's Avatar
muzikmanwi
Sounds like the insides of the converter is broken up and rattling.
Old Jun 9, 2011 | 11:48 PM
383vett's Avatar
383vett
Old Jun 10, 2011 | 06:59 AM
jsinga's Avatar
jsinga
Hey, you need to do something soon! What you hear is the cat brick loose. Eventually it's going to break up and plug your main cat.
Ask me how I know, I was 150 miles from home in the middle of the night. For a while I was doing 45mph and that was it.
My Y pipe came off without breaking any studs in the exhaust manifolds. Took a long piece of 1/2 pipe and beat the bricks out and put the pipe back on.
If you do it soon maybe you won't trash the main cat.
Nobody has ever said they couldn't pass smog with a only a good main cat if you are worried about it.
JS
Old Jun 10, 2011 | 08:20 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Why don't people read the original post????
Its a freakin 96, there is no Y pipe and no pre-cats.
Chris - your going to need to find a shop that will replace your original cats with replacement cats. Find a good exhaust shop.
Old Jun 10, 2011 | 08:25 AM
muzikmanwi's Avatar
muzikmanwi
OP is the one that called it a precat so you must not of read it either.
Old Jun 10, 2011 | 08:27 AM
chrisd0729's Avatar
chrisd0729
It looks like the cats are all bolt-on between the exhaust manifolds and mid-pipe. I figured I could do this in my garage and not have to pay a shop to do it....
Old Jun 10, 2011 | 08:52 AM
muzikmanwi's Avatar
muzikmanwi
Hardest part will be unbolting from the manifolds if the studs/nuts are rusty. Start spraying them down with PB Blaster so they free up before you even try to loosen them.
Old Jun 10, 2011 | 02:30 PM
j-wireman's Avatar
j-wireman
Well, that's what the owner said...
To Rattling in front y pipe
