Raising the drivers side front.
Old Apr 23, 2002 | 10:03 AM
DUCKHOOK's Avatar
DUCKHOOK
Default Raising the drivers side front.
Is there anyway to adjust the front end up or down, or would somthing like this call for some type of spring shims.
I would like to raise the drivers side front about 1/4 inch this is how much lower it is VS. the right.
Thanks!
Old Apr 23, 2002 | 10:55 AM
Goody's Avatar
Goody
Default Re: Raising the drivers side front. (DUCKHOOK)
The only way I can think of to do this would be to get a stock spring and shave off 1/4" off the opposite side to achieve the effect you desire. I don't think you want it any higher than stock do you?? Has car been lowered by a previous owner or you?? 1/4" really isn't significant come to think of it. You could bounce the car by hand a few times and remeasure just to see if the measurements are the same. But still.....1/4"?? But, its your car and if it's that important to you go for it. :seeya
Old Apr 23, 2002 | 12:03 PM
ralph's Avatar
ralph
Hey Duck, i have the same situation and i'm about to install a second shim under the spring. I just replaced the z51 spring with a softer spring i got from the junk yard. Maybe the driver was 300lbs or something, but the drivers side is about 1/4 lower and just enough to bottom out my HAL shock. So rather than destroy the shock...i'm going to try to raise the srping a lttle by adding another shim. Shoot me a note next week and i'll let you know how i made out.
Old Apr 23, 2002 | 12:31 PM
Thumper's Avatar
Thumper
Cruise-In II Veteran
Default Re: Raising the drivers side front. (ralph)
Ralph,
Does your tire ever run on your hood or does the shock bottom out first? Just curious.
Old Apr 23, 2002 | 02:10 PM
ralph's Avatar
ralph
Default Re: Raising the drivers side front. (Thumper)
How u been Thumper.....
No rubbing, but the shock bottoms. Not even a problem with street tires, but when i have the skinnies up front for drag racing, it gets a little lower (cause the center of the wheel is further out). I dont even feel the shock bottom, but i have put gease on it, so i know it is. It only has about 1 1/4" of compression travel on the drivers side and maybe 1 1/2" on passenger side....passenger side generally doesn't bottom out tho.
To Raising the drivers side front.
