93 ecm
Old Jun 13, 2011 | 09:23 PM
ronmitchell's Avatar
ronmitchell
5th Gear
Default 93 ecm
Need to find a ECM for a 93 LT1. I have found that they are hard to come by! Having mine rebuilt and hope this works. Any suggestions?
Old Jun 14, 2011 | 02:30 AM
rodj's Avatar
rodj
Originally Posted by ronmitchell
Having mine rebuilt
Only option available now.
Discontinued by GM many years ago
Old Jun 14, 2011 | 03:33 AM
toptechx6's Avatar
toptechx6
Here is a list of companies that rebuild, no personal experience with any of them to share.
http://www.siaelec.com/
http://gmautocomputers.com/
http://www.bsecorp.com/
http://www.autoecms.com/
I have used a local guy here in Florida to rebuild one in my Dodge truck, no problems with the work. I only have his e-mail, his name is Louis. Good luck.
acquaauto@aol.com
Old Jun 14, 2011 | 10:38 AM
surfer93's Avatar
surfer93
Autpartswarehouse.com has them.
Napa and Autozone have them, but are pretty expensive.
SIA will rebuild yours, but you have to send it in and there is a 3-4 week turn around.
Having had a 92 and 93, the ECM's that you buy that are rebuilt, are not rebuilt very well. Heat soak is a major problem with our ECM's and since they do not test the ECM's under duress, they don't find parts that do not work right when hot. This is my theory and since I went through 3 ECMs, I feel I am correct, that and I called SIA and asked them.
Do your self a favor and when you get your new ECM, wrap it up in something heat resistent.
Stepping down from my soap box.
Old Jun 15, 2011 | 03:03 AM
rodj's Avatar
rodj
Any suggestions?
Be quick
http://cgi.ebay.com/ebaymotors/LT1-P...Q5fAccessories
Old Jun 15, 2011 | 01:05 PM
ronmitchell
5th Gear
Thanks for your help and advice! I will check these companies out.
Old Jun 15, 2011 | 02:53 PM
surfer93's Avatar
surfer93
Originally Posted by rodj
This is a F-Body, you will need a vette chip.
Old Jun 17, 2011 | 04:46 AM
rodj's Avatar
rodj
One assumes his current ECM has a chip in it that can be swapped over to a different ECM?
To 93 ecm
