You do not say what year car and your profile is not filled out to give us a hint, you will get much more accurate advice if you remember to include that in your initial post. Here is a link to some instructions for removing the radio, most steps are the same for removing the C68 control head.
Use a test light to check each fuse in the block, if you verify all are good there is no need to identify which one protects the mirrors. Remember that some only have power with the key in the ON position.
Consider purchasing the correct factory service manual for your vehicle, it often pays for itself with a single repair.
Default Want to change radio but ,,,,,
I am looking to change out the stock am/fm "cassette" radio that's in a 1990, And my question is can any chevy padio work without any problems ???
