Replacement Brakes for 94 LT1
Old Apr 23, 2002 | 01:50 PM
James94LT1's Avatar
James94LT1
Default Replacement Brakes for 94 LT1
I wanted to know what you guys have replaced your brakes with, any particular brands, etc.
I took my car to the dealer and they wanted $525+ tax for 2 front rotors and pads. I think they were trying to give it to me since they are the only Chevy dealer around here in Bum (you know) Egypt!
I am going to do it myself now! Any special pads I should think of?
Thanks!
Old Apr 23, 2002 | 01:52 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Default Re: Replacement Brakes for 94 LT1 (James94LT1)
What do you want to do -- just replace pads or upgrade rotors and calipers, too?
Old Apr 23, 2002 | 02:01 PM
James94LT1's Avatar
James94LT1
Default Re: Replacement Brakes for 94 LT1 (94vette)
I may upgrade rotors, keep stock calipers though. I guess I really wanted to know best pads for the money? As well as rotors. It isn't my daily driver and the racing it sees is on the dragstrip.
Rich's94vert's Avatar
Rich's94vert
BUY THE FRONT OEM PADS FROM; THE LAST DETAIL IN ATLANTA FOR LESS THAN 150.00. IF YOU NEED ROTORS TURNED TAKE THEM TO A NAPA STORE 10 TO 12 DOLLARS EACH. JOB SHOULD NOT TAKE MORE THAN 1/2 HOUR PER WHEEL. REARS ARE LESS EXPENSIVE. GO TO http://WWW.TLD-CORVETTE.COM. GOOD LUCK
Old Apr 23, 2002 | 02:27 PM
YLO Z06's Avatar
YLO Z06
Default Re: Replacement Brakes for 94 LT1 (Rich Shriver)
Other good pads that people here have installed are Performance Friction Z-Rated (available at Auto Zone) and Hawk pads. If you really want to spend some $$, upgrade your front brakes to 13" HD brakes ala Grand Sport. Probably run you about $550 from Jeff Kopp at Superior Chevy (18carfan here on the Forum).
Old Apr 23, 2002 | 05:16 PM
John Row's Avatar
John Row
Ditto.
Don't bother to upgrade rotors, stocks are fine unless you race or have too much money.
I'm running EBC GreenStuff pads, but I upgraded to GS brakes at the same time so I don't know how much difference they make.
To Replacement Brakes for 94 LT1
