Intermittent Code
Old Jun 16, 2011 | 10:44 AM
RubiconM7's Avatar
RubiconM7
Default Intermittent Code
I have an 85' corvette and I am getting a intermittent service engine light. I jumpered the aldl and I get the typical 1 flash followed by 2 flashes (3 times) then it flashes 4 times with no pauses in between (3 times) What code is this?
The vette is also a little hard to start (cold and hot) and has a slight hesitation when you mash on the throttle. I was going to check fuel system. TPS and timing should be spot on.
