help
Old Jun 16, 2011 | 10:16 PM
barrymac's Avatar
barrymac
7th Gear
Default help
doz a 1990 vett key have a chip on it????????????????
Old Jun 16, 2011 | 10:25 PM
oldalaskaman's Avatar
oldalaskaman
if it has that little dot up by the big end by itself , yes it does
Old Jun 16, 2011 | 10:31 PM
barrymac's Avatar
barrymac
7th Gear
man i have tryed everything it still wont fire lol
Old Jun 16, 2011 | 10:37 PM
jfb's Avatar
jfb
The contacts on the ign key is a chip resistor and if the contacts in your ign lock make a good connection to it, (these contacts don't last forever) this tells the VATS module (CCM in later Vettes) that the correct key is being used and the CCM closes the start enable relay allowing the starter solenoid to get 12v from the ign sw and it also allows the injectors to pulse to start the car.
Old Jun 16, 2011 | 11:04 PM
barrymac's Avatar
barrymac
7th Gear
it will turn over but it wont fire and security light is flashing
To help
