89 Vette with code 36
Old Jun 17, 2011 | 10:13 PM
Sirwilliam1229's Avatar
Sirwilliam1229
Default 89 Vette with code 36
I have a 89 Vette, that is giving me a code 36. I replaced the relays a couple years ago, b4 letting it sit up. I don't know what else to do (Clean MAF sensor)? Can anyone help me on this one? The car runs fine.
Old Jun 17, 2011 | 10:25 PM
WW7's Avatar
WW7
Here are the posible causes of a Code 36. I would disconnect the MAF sensor and clean the contacts on that and on the relay, after many years connected the pins can get corroded and not make good contact..WW
Code 36- Check connections at MAF, MAF relay and MAF Burn off relay. Check resistance of MAF relay and MAF burnoff relay with digital Ohm meter. replace if less than 18 Ohms. Possible ECM failure..
Old Jun 17, 2011 | 10:27 PM
Tony A.'s Avatar
Tony A.
Beyond giving the MAF sensor a thorough cleaning with spray cleaner, visually inspect the connector and ensure it is seated well. Mine was slipping off after I did some work (radiator) and it was throwing that code.
If the burnoff element is not functioning, then you may have to switch to a new MAF unit to get the code to disappear. The car runs fine because the MAF sensor apparently isn't so dirty yet that it matters.
Can you hear the element pop (heating up) once you stop?
Old Jun 18, 2011 | 12:32 AM
Sirwilliam1229
I can't hear any pops are anything, I just keep clearing code 36 (Pulling the fuse). I will clear the contacts tomorrow morning (Saturday).
Old Jun 18, 2011 | 05:51 PM
Sirwilliam1229
I cleaned the MAF unit and burnoff relays, with a MAF cleaning solution. I then pulled the ECM fuse for approx 10 seconds, in order to clear any codes. Once I started the car, I still get code 36. What am I missing?
Old Jun 18, 2011 | 06:45 PM
Sirwilliam1229
Ok, the pulling of hte ECM fuse did not work. But, once I disconnected the negative cable for 10 seconds, the code went away. I would not have thought about cleaning the burnoff relays, and the MAF connectors. Thanks a million miles!!!
To 89 Vette with code 36
