94 LT1 Steering rack Problem
Old Jun 19, 2011 | 09:07 PM
tporter's Avatar
tporter
Default 94 LT1 Steering rack Problem
Steering rack has a clunk in it when i move steering wheel back and forth. Is this a common failure? Is there any fix except changing the rack, also, can someone tell me what size socket I need for the rear hub nuts?
Tim
Old Jun 19, 2011 | 09:35 PM
Repzard's Avatar
Repzard
Tim
Sure its from the rack and not the u-joint on rack arm?
Also check you tie rod ends for play, those could cause play and make noises
Old Jun 19, 2011 | 09:41 PM
tporter's Avatar
tporter
I checked the tie rod ends, they're tight, I can't really see the Ujoint
Old Jun 20, 2011 | 08:43 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If you are talking about the big axle nut IIRC its 36mm (I'll double check tonight)
If you are talking about the torx bolts holding the hub to the spindle IIRC its T55
To 94 LT1 Steering rack Problem
