BAD Ecm?
Old Jun 20, 2011 | 10:54 PM
zbestzeus's Avatar
zbestzeus
5th Gear
Default BAD Ecm?
Car was running fine, stopped it, started it back up and it had a hard time idling. Shorted the ADL connector, Check Engine Light did a quick flash and then stayed on not blinking. Disconnected battery for a bit, then reconnected. Normally this will reset the Check Engine Light but it stayed solid when I turned the car back on. ECM is about 3 years old, sound like it needs to be replaced?
Old Jun 21, 2011 | 12:48 AM
zbestzeus's Avatar
zbestzeus
5th Gear
NVM, EPROM chip was loose
