Head Milling
Old Jun 21, 2011 | 04:57 PM
The Bus's Avatar
The Bus
Default Head Milling
How much metal can be taken off a set of 113 heads before it would cause problems with gaskets and block alignment????
Old Jun 21, 2011 | 06:10 PM
C409's Avatar
C409
..... The surface hardening on factory aluminum cylinder heads is at most .020 deep ... my machinist did not want to take off more than .013 for that reason ...
Old Jun 22, 2011 | 08:09 AM
ddahlgren's Avatar
ddahlgren
They are not surface hardened they are heat treated all the way through. What happens during use especially if overheated they get softened and then it is very hard to get a good surface finish when milling them. It does not take much to screw up the alignment of the intake gaskets when milling heads. 0.020 is probably a sensible limit.
Dave
To Head Milling
