86 Power Steering Not Smooth
Old Jun 27, 2011 | 12:49 AM
MBE111's Avatar
MBE111
Default 86 Power Steering Not Smooth
I have an 86 that I have been working on for the past year and a half. Just recently have started driving it and am working on getting the bugs out of it.
The car sat in a barn since 2002.
My problem is the power steering. When driving the car, the steering wheel takes an extra effort and then smooths out with normal effort when making the slightest turn, at any speed. It is as though the ball joints are froze up, but they aren't. The wheels turn side to side when the car is jacked up in the air with no problem. I should also mention that it pulls a little to the right.
I sucked the power steering fluid out of the reservior and then cracked the lines on the steering tube. I ran the engine to pump out the old P/S fluid, it was really dirty compared to the new fluid that I put back in. I also flushed the system with diesel fuel for a thorough clean prior to the new fluid.
The cleaning and flushing helped some but the extra effort is still there when making a turn.
Is there a centering valve or a proportioning valve in the system that needs cleaning?
I think the right side pull would go away with an alignment.
I think the steering extra effort is more like a stuck hydraulic valving issue.
Anyone have the same symptoms? How did you fix it?
Old Jun 27, 2011 | 11:37 AM
leesvet's Avatar
leesvet
This is a common ailement of rack & pinion....its called "morning sickness".
Fix it by adding a bottle of LUCAS Rack & Pinion conditioner and stop leak. The problem will go away immediately. Run the LUCAS in ALL R&P systems to prevent this.
This is one product that actually does what it claims.
Old Jun 27, 2011 | 11:46 AM
DanZ51's Avatar
DanZ51
Yup, morning sickness.
I don't know about the Lucas (never tried it). When my rack went years ago, I just bought another rebuilt rack; complete with tie rod ends. IIRC GM had these racks built with the piston moving in aluminum. As it gets old the bore wears. Cold morning, or cold fluid = no power steering, at least for a moment. Rebuilt ones are usually resleeved (the bore) with a steel sleeve so they will actually outlast the OE.
Old Jun 27, 2011 | 12:41 PM
oldalaskaman's Avatar
oldalaskaman
lucas rocks
To 86 Power Steering Not Smooth
