Fuel smell / valve overlap?
My latest Hyd-Roller cam, 238/242 - 293/300 @ .592 lift,,,really pepped up the engine and I love the drive-ability but the occasional fuel smell while idling/sitting in traffic is becoming pretty annoying.
I had my 86-89 Stock ECM tuned by a local tuner that did an awesome tune, (www.prodynotech.com) the tune is 100% drive-able in all conditions, no bucking, sputtering hesitation etc.
Do you guys with aggressive Hyd-Roller cams have this same issue?
If this cant be tuned out, as my tuner says it cant, then I will change my cam and maybe downsize my heads from AFR 210CC to 195 CC as well if I do a cam downsize. The tuner said , " this cam is on the ragged edge of tune-ability for the street"
I am still considering building a new engine with more cubes and or forced induction but that is a year away for me right now
What is your cam lift and lobe seperation. You are running a sligtly more duration then I do. I have a 236/242 stuffed in the 421, but I have a tad more lift.
Maybe some cats to clean up the smell a bit? Or maybe you have those....
Jim Barth and Paul Thompson are probably one of the two most knowledgeable guys on the forum, however Paul isnt on much so you can pm or email him this thread because he has alot of tuning experience.
If I need a FAST, then that's what I'll do, I'm sure it will help with a 421, or a 434 or a Supercharger build etc.
It may be necessary to limit the INT and/or BLM or even to prevent closed loop operation or BLM updates below x rpm via special programming.
Otherwise, you can try and run it as lean as possible at idle and retard the ignition timing a bit to put more heat into the exhaust.
If its rich in an open loop idle, then maybe too much injector offset, a too rich MAF cal or a too rich target AFR.
Gotta determine the cause of the richness first.
I certainly thought the tuner was going to get this ironed out but evidently not,,, I just don't have the time or desire to learn the GM 86-89 ecm tuning system
"The rolling misfire from overlap increases the Hydrocarbon output and the only cure is to add cat converters....... if you go leaner than 14.7 with an aftrmarket engine management you will stall. Might try a higher desired idle rpm "
anybody think a Hi - Flow cat will take the smell away?
