Another Question Re: Air Intake
Old Jun 27, 2011 | 06:10 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Default Another Question Re: Air Intake
I'm looking at getting the K&N airfilter. Many people here said to cut the lid. Is that a lid that K&N sells or are you talking about cutting the stock lid? Also, how should I cut it?
7
Old Jun 27, 2011 | 06:21 PM
cgantner5150's Avatar
cgantner5150
Just cut the stock lid center section out (part with the louvers). Make sure to leave enough frame to hold the filter in.
Sorry - one of the few things that I don't have a picture of.
Old Jun 27, 2011 | 06:22 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Cut out the grill on the stock air box lid with whatever metal cutting tool you have saw, etc. Save yourself a few bucks and just buy a new stock paper filter if needed. You won't tell any diff with the K & N.
Old Jun 27, 2011 | 06:41 PM
joe paco's Avatar
joe paco
good advice, duck. goin' against the collective "wisdom" ain't easy to do. people are going to swear that you have lost your marbles.
Old Jun 27, 2011 | 06:54 PM
cv67's Avatar
cv67
St. Jude Donor '05
BADDUCKS right paper filter is just fine.
K&N lets more air through but lets more dirt in too.
I have run another car with no air filter and putting the air cleaner on with paper filter and could tell 0 difference.
Old Jun 27, 2011 | 07:07 PM
pmihaltian's Avatar
pmihaltian
Slingshot
You can pick one up at most of the Corvette parts houses or, as mentioned above, just cut your OEM filter cover yourself.
http://www.ecklerscorvette.com/corve...1985-1989.html
Old Jun 27, 2011 | 09:33 PM
Steve20's Avatar
Steve20
I picked up an extra lid, cut that one out, and I could tell no difference with the cut vs stick lid.
Used oil analysis of cars running KN Air Filters almost always show a higher level of silicon in the oil. Silicon is a very abrasive substance normally ingested through the (KN) air intake and it causes a lot of metal wear. When you see high silicon levels in used oil analysis, you will also see high levels of iron tin chromium and lead. Guess where those are coming from?
Steve
Old Jun 29, 2011 | 08:50 PM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
I like these,
http://www.koolblue.com/index.html
Old Jun 29, 2011 | 09:48 PM
Tony A.'s Avatar
Tony A.
Originally Posted by ks5shooter
Any supporting info re: their performance? Just curious...always looking for the best solution.
Old Jun 30, 2011 | 05:59 PM
rickneworleansla's Avatar
rickneworleansla
Here's an old pic of the cut lid before I went with the Ram Air setup.
Old Jun 30, 2011 | 10:58 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Hey everyone. On my 1996 the headliner and board have separated from the top of the car. It rattles all the time and gets really annoying. Thanks, Ed
Old Jun 30, 2011 | 11:08 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I wonder how much the sound changes with a cut lid? In the old days, flipping a carbed air cleaner (or running an open sandwich) made quite a varoom noise.
So take it down and reglue/replace it. That's a pretty easy job. The perimeter (trim) of the targa will come apart to let you complete this job.
Old Jun 30, 2011 | 11:26 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Old Jul 1, 2011 | 07:27 AM
pmihaltian's Avatar
pmihaltian
Slingshot
You need to fill out your user profile.
To Another Question Re: Air Intake
