Transmission Shift Points??
Old Jun 27, 2011 | 10:28 PM
rrt898's Avatar
rrt898
Default Transmission Shift Points??
I have a stock 1986 automatic coupe. I want to know at what RPM should the car shift from 1st to 2nd?? The car shifts around 2300 is this correct??
thanks......
Old Jun 27, 2011 | 10:43 PM
RocketSled's Avatar
RocketSled
You need to adjust your TV cable: http://forums.corvetteforum.com/c4-g...ownshifts.html
If that brings you no joy, ensure that cable is kink-free and easy moving.
ETA: shift points are based on throttle position...2300 rpm is a possible shift point, but WOT should have it shifting higher than 4000rpm or so.
