Stuck plugs
Old Jun 29, 2011 | 05:36 PM
vette/fun's Avatar
vette/fun
Cruising
Default Stuck plugs
Ok this may sound stupid but I was given a 1986 corvette with 58000 miles on it. I guess I got one of the last off of the production line because it has aluminum heads. My question is I was going to check the plugs but it looks like they have never been changed and are so tight I am somewhat leery about using to much force to loosen them. Any suggestions would be welcome.
Thanks in advance for any help
Old Jun 29, 2011 | 06:01 PM
oldalaskaman's Avatar
oldalaskaman
soak w/pb blaster, try to slightly tighten them first, sometimes it breaks things loose with out breaking things.
Old Jun 29, 2011 | 06:09 PM
vette/fun's Avatar
vette/fun
Cruising
Thanks I will try it. The car runs ok but I know it must need plugs they are 25 years old haha.
Old Jun 29, 2011 | 08:56 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
After soaking with PB Blaster when the engine is cold soak each plug with a fast evaporating contact cleaner. The cold produced by the CC might "shrink" the plug threads enough to break them loose.
Old Jun 29, 2011 | 09:40 PM
Tony A.'s Avatar
Tony A.
Be sure you only go to take out the plugs when the engine is cold, otherwise you may strip the threads on the alum head.
Old Jun 29, 2011 | 09:52 PM
l98tpi's Avatar
l98tpi
Max G’s
Try this- Start the car and let run for around 2 or 3 minutes. Then remove plug wires and remove the plugs. It is easiest to remove the plugs, especially on the passenger side, by removing the splash shield. It is also a good idea to use an extension and a universal when removing and installing the plugs, that will assist in getting the plugs threaded back in correctly.
Old Jun 29, 2011 | 10:16 PM
JackDidley's Avatar
JackDidley
Change the ones that come out easy. Leave the others until you are up for a major project.
Old Jun 29, 2011 | 11:15 PM
Sidney004's Avatar
Sidney004
You don't want to create a problem if the car is running fine.
If it were me, I would leave the plugs alone. Save your energy for fixing something when its actually broken. You will have plenty of opportunities.
Old Jun 29, 2011 | 11:17 PM
Tony A.'s Avatar
Tony A.
Totally agree on removing the splash guard (passenger side).
The one thing I found really helpful was I bought a plug socket that is on a swivel. It allows the drive socket to get up in the right angle and seat on to the plug. Made a huge difference....good luck!
http://shop.advanceautoparts.com/web...T|GRP2062_____
To Stuck plugs
