84 CFI to TBI
Old Jun 30, 2011 | 09:51 PM
jcro61's Avatar
jcro61
Default 84 CFI to TBI
My 84 was kind of hacked when I got it and was running a carb. I have since traced all the wires down and installed a single tbi(I chose this route as it was much more cost effective than trying to get a crossfire).
I have everything running well but my throttle and tv cable are kind of out of line.
The stock tbi bracket(from a 90 camaro i think) sits on the far back bolt of the intake manifold. This configuration makes the throttle cable way too short to reach the throttle body. It has enough overall length that I can use it if I had a proper bracket to hold it. Has anybody done this swap and had this same problem? How did you manage to fix it? ie what brackets did you use.
Also the TV cable is majorly short. It does not reach anything at all. I am fairly certain I will probably have to replace it with a longer one.
Any and all help is appreciated. Thanks.
Old Jul 1, 2011 | 03:00 AM
ConnecticutJunkman's Avatar
ConnecticutJunkman
I would think all you need is the TV cable and brackets off a third gen L03 camaro/firebird. Try asking around over at ThirdGen.org. Most guys end up throwing away TBI stuff..
If your TBI really is off a camaro then you may have to upgrade the injectors.. TBI only came on the 305's. 350s where TPI. 350 TBI only came in trucks.
Old Jul 1, 2011 | 07:53 AM
jcro61's Avatar
jcro61
The bracket is from a camaro and it doesnt allow the cables to reach. the injectors are off a 350 truck.
Old Jul 1, 2011 | 12:14 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I believe you...but that doesn't make much sense. The TV cable mounts right about in the middle of the CFI intake, so you're only talking an inch or so diff going from CFI (assuming your TV cable is the original CFI cable) to TBI...if that.
How was the TV cable hooked up to the carb? Locations should be pretty darn similar as the TBI unit...
-Tom
Old Jul 1, 2011 | 12:48 PM
cv67's Avatar
cv67
St. Jude Donor '05
Wouldnt the cable and brackets off a similar vintage van work?
Those were single TB also. Just a thought.
Old Jul 1, 2011 | 02:13 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
TBI Van, TBI truck, TBI Caprice, TBI F-body...same-same.
Old Jul 1, 2011 | 10:06 PM
jcro61's Avatar
jcro61
Your telling me lol. The throttle cable is very long. It will reach all the way to the water neck if you dont hook it up to the bracket. they were both hooked up to the bracket on the carb but both had like wire wrapped around them to make up the difference between the cable and the linkage. The whole thing was pretty rigged up. Maybe the car has the wrong cables on it? The car is 27 years old so who knows what happened to it in recent years. I am gonna try to find a store that has the stock cables in stock so I can check out the lengths etc.
Old Dec 7, 2011 | 10:10 PM
jcro61's Avatar
jcro61
Just wanted to kind of update this for anybody who might come across this post in the future. The tv cable was too short because on the cfi the linkage is (from what I can see in blurry pictures on google) in the middle of the two throttle bodies and on all the other setups it is on the drivers side. So once I replaced the TBI plate as mentioned below, the cable was still short and when hooked up stopped the throttle from opening all the way. I replaced it with a tv cable from a camaro and it now works fine.
In relation to that the TBI adapter I used to mate the TBI to the 2101 manifold I have was center mount and you need a rear mount to match the factory location like if you had a stock tbi manifold. I also replaced the throttle cable because it was so long and kind of in the way of other stuff.
So that was the deal on my problems.
Old Dec 8, 2011 | 09:51 PM
danvetman's Avatar
danvetman
Would this be an upgrade over the CFI, as far as performance and horsepower? Probably a dumb question but this sound interesting.
Old Dec 8, 2011 | 09:57 PM
jcro61's Avatar
jcro61
I am not sure stock cfi to stock tbi. My car did not even have the CFI on it but the wiring was mostly there. It was just easier and cheaper for me personally to get the tbi setup at the junkyard than to hunt down the CFI as all the CFI setups I could find nearby were so expensive I could swap to TPI or something like that.
If my car had come into my hands with the CFI I would probably have left it on the car.
Old Dec 9, 2011 | 07:38 AM
ex-x-fire's Avatar
ex-x-fire
It opens up alot of possibilities w/ different intakes, you can use any 4bbl. type intake w/ a tbi adaptor.
Holley makes a tbi intake, it has all the brackets so you can reuse your original throttle/tv cables. The best tbi to use is the 87-89 chevy truck model, w/ 350 injectors. The tps wiring is different on later years. The throttle arm maybe different too.
Old Dec 9, 2011 | 09:01 AM
danvetman's Avatar
danvetman
Thanks Ex-X-fire. Do you lose much torque when converting to a truck TBI? I can see where you would gain some horsepower. Just wondering.
Old Dec 9, 2011 | 10:09 AM
jcro61's Avatar
jcro61
I used a tbi from a later year camaro and the tps was different. The wire colors are the same just the plug is different so if you had to run a later one all you have to do is change the connector.
Old Dec 9, 2011 | 07:18 PM
ex-x-fire's Avatar
ex-x-fire
Lets compare the hp ratings from the factory.
84 L83 205hp 290ft/lbs. These had 9.0 comp ratio, decent cam for the time, a some what tuned exhaust manifolds, & an exhaust system that was much better then any of the earlier cat converter systems before it.
88 Chevy tbi 5.7L 200hp 300ft/lbs. These had crappy heads, restrictive exhaust manifolds, single exhaust, & a lame cam. It does have 1/2 of compression over the L83.
Low end might be alittle less, but throttle response is improved. Power band is wider.I think these tbi systems like intakes with less plenum volume, kinda like a 2bbl carb that makes great torque. The crossfire intake has a large plenum & high velicity runners, they just cant move enough air/fuel at higher engine speeds.
Old Dec 13, 2011 | 04:23 PM
Rohn's Avatar
Rohn
I used a Holley Projection manifold with a universal adjustable Edelbrock bracket. Fit fine with stock cables.[IMG][/IMG]
Old Dec 13, 2011 | 05:02 PM
87bob's Avatar
87bob
Veteran: Coast Guard
I comend you for trying this as you will see better fuel economy cold starts better throttle response than a carb.
Old Dec 13, 2011 | 06:53 PM
jcro61's Avatar
jcro61
Which edelbrock bracket was it exactly?
To 84 CFI to TBI
Old Dec 13, 2011 | 06:56 PM
ex-x-fire's Avatar
ex-x-fire
My projection intake included throttle/tv brackets, plus other hardware.
Old Dec 14, 2011 | 03:30 PM
Rohn's Avatar
Rohn
Sorry dont know which one. I purchaed from Summit 4-5 years ago.
Is there more than one?
Old Dec 14, 2011 | 04:50 PM
Jay7199's Avatar
Jay7199
I just completed this swap aswell, im happy with it. It will be alot better with some tuning to the ECU.
http://www.youtube.com/watch?v=XfisT...A&feature=plcp
