Yes, drivers side...but if it is spot leak...spray....could be going to right side. I would check the valve covers first. Then take a mirror to look at the rear china wall. Can you tell is it a leak over a large area or concentrated?
Oil pressure sending unit on the back of the block.
I had a leaks everywhere, except the valve covers.
Rear China wall was the worst, Oil pressure and and temp, plus their connecting pieces.
You almost have to get the harness all the way off, to get the intake back on and for those who are going to try this, if for any reason you lift the intake back off, clean and reapply the RTV, before reinstalling.
Both times I have had leaks after taking the intake off, it was because I lifted the intake off to realign.
