1994 corvette water pump bolt problem
Old Jul 7, 2011 | 01:48 AM
oliver's Avatar
oliver
Default 1994 corvette water pump bolt problem
I started to replaced my opti today and I am having trouble getting to the middle bolt on the drive side of the water pump. I can not line up a socket and extension to the bolt,the power steering pulley is in the way. I even went threw the slot in the pulley and still can not get to the bolt. I hope I dont have to remove the power steering. Is there a easy way to get this bolt out, any help would be great?
Thanks Mike
Old Jul 7, 2011 | 01:58 AM
Repzard's Avatar
Repzard
When I did mine just 2 weeks ago
I used a swivel end extension to get that little clearance needed to clear PS pulley.
Old Jul 7, 2011 | 10:24 AM
dewfall's Avatar
dewfall
Thanks Mike
Go to the bolt from under the PS pulley, or try a universal joint behind the socket. It is certainly possible with some manipulation, I've had my water pump off twice. The bolt should not be so tight that the socket has to be on squarely to get enough grip.
Old Jul 7, 2011 | 10:53 AM
96GS#007's Avatar
96GS#007
Just remove the four 10mm bolts that secure the PS pump to the accessory bracket. There is ZERO need to loosen or remove any of the PS lines. With the four bolts removed, push the PS pump aside (it will easily move), and then remove the water pump bolt. Should take about 2 minutes.
Old Jul 7, 2011 | 12:04 PM
oliver's Avatar
oliver
Thanks everone I am going back in the garage to see if I can get this bolt out.
Mike
Old Jul 8, 2011 | 12:17 AM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
hope this helps
[IMG][/IMG]
To 1994 corvette water pump bolt problem
