fuel pump
Old Jul 7, 2011 | 02:08 PM
cww's Avatar
cww
1st Gear
Default fuel pump
1985- someone took the fi system out and put a carb. on.I need a fuel pump thas has 4-8 lbs press.Can I put a external f.p. or do they make a low press. elec. fuel pump?
Old Jul 7, 2011 | 03:17 PM
1963SS's Avatar
1963SS
If you have the stock pump now could you just install a fuel pressure regulator? Holley makes some as do many others. Should be in the $30.00 price range. good luck
