Some questions 92 LT1
Old Jul 8, 2011 | 02:56 PM
Pietro Bisanti's Avatar
Pietro Bisanti
6th Gear
Default Some questions 92 LT1
Hi guys,
I recently bought a 92 LT1 Vette and I am asking your opinion about these issues:
1) At startup the ABS ACTIVE light doesn't appear as a self-test of the ABS, although I checked that the ABS works, infact it kicked in during some hard stop and its light appeared on the control panel
2) Despite the engine runs smoothly I can smell some gas coming out of the exhaust, as if the car is running too rich
3) The speed indicated by the digital dash in incorrect, at least of minus 20 km/h
I appreciate any comment!
2) Although my engine runs smoothly I
Old Jul 8, 2011 | 04:11 PM
STL94LT1's Avatar
STL94LT1
Is the car stock, any modifications?
Old Jul 8, 2011 | 04:57 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Check the bulb for the ABS light; it may just be burned out.
You should start your diagnostic process by pulling the engine codes through the ALDL and see what you discover.
Old Jul 8, 2011 | 06:36 PM
markKlein's Avatar
markKlein
This is probably a stupid question, but regarding the speedometer, are you sure it is set to display metric units and not english?
Old Jul 8, 2011 | 11:56 PM
surfer93's Avatar
surfer93
Originally Posted by Pietro Bisanti
Hi guys,
Check bulb, mine burned out
OHM injectors, if they are under 12, replace and Speed Density cars ECM do not handle change well. Also check O2's and fuel pressure regulator
Did someone change the gears or VSS?
See comments in RED
To Some questions 92 LT1
