I'm thinking of doing new heads, which am I better off doing, porting my stock lt1 heads or buying new AFR's probably 190? Oh and as always this is on a budget I'm hoping to spend under $2000. Thanks.
And I would like to use the same heads if I ever decide to do a 396ci stroker.
LT4 heads are a bargain at about $1300 a set assembled...
Unless you're really serious about making horsepower, they'll do just fine.
The bonus is "no exchange". Sell or keep the original heads.
That also requires a new intake aswell. I guess I'm not sure how much airflow I need to make the HP I want. I'm assuming more is better, please correct me if I'm wrong. and this is something I'd want to do just once. I wouldn't want to port the lt4 heads later which I believe would give really close to the same airflow as the lt1 heads ported.
To make real decent power you will have to port either head. This is where it makes a big difference on who ports them as well and the results. I am uing stock LT1 castings on my 396 that have been worked on a couple of times. It makes good power, but if I were to get really serious (which I may someday) I will go with an AFR 210 head. 396 is a lot of cubes and can handle the bigger ports without effecting drivability.
For the money you want to spend, just port what you have. Do the valves, guides, porting, bowl work, etc.
Yeap, dont waste your $ on LT4's and for most applications I dont suggest an aftermarket casting to customers :). The lt1's are enough head to make over 425rwhp w/o anything extreme & a daily driveable hydraulic roller :)
1. You can buy AFR LT1 heads which are good enough to make 525 hp approx. 1800.
2. Have yours ported and redone 2000 - I would go with speed demon motorsports if you go that way because they seem to know what they are doing and good head porting needs to be done by guys who are experts on your particular head.
3. Canfield also makes LT1 heads that are pretty good and cheaper than AFR.
4. The LT4 heads are a good option also. Consider that GM went to a new port design to make the LT4 instead of keeping the LT1 castings.
If you are staying NA I would just get your stockers ported, they are capable of serious power. If you are going to run a blower or Nitrous, I would opt for the AFR's personally. Just so you can have a thicker deck. Not that the stockers can't hold it, it's just me.
For all intents and purposes, unless you need ALOT of material to remove, or a huge chamber, AFR's are a waste of money. Them makin 525hp.. i dunno, you'd need something to flow like their cnc competition porting claims ... we've yet to see a single AFR head even get close to the claimed numbers. Theyre getting better in recent months, but still not as good as a professional handport job. Theyre awful expensive as well last i saw, IIRC competition ported 210's were $2650ish lol... thats rape for an 'ok' head with mediocre components. As far as canfields.. it seems noone buys them anymore, they were less than spectacular.
We're not having problems getting 420+rwhp with worked lt1's and a hydraulic... working on 450+rwhp out of lt1's & our cam :).... There's potential there, just gotta find someone who knows how to milk it for all its worth :D
I'm installing my NX system in the next week or so and it'll have a 100-150HP shot in it, how would this affect things? could you explain the deck thing to me?
I don't know how you can choose heads without knowing what cam, exhaust and targeted hp you are looking for. Not a lot of difference in well done LT1 and LT4 heads. Why don't you let us know what you hope to accomplish?
what would I like to accomplish...hmmm.....1000+HP :D ok, maybe not quite that much, but I would like to get a 425-450HP 350ci plus have an additional 100-150HP NX shot to go on top of that. Once I reach that stage I'll probablly get it stroked to a 396ci and keep the NX. I do realize that this is going to take a while to do considering my funds are limited, but there's some fast cars running around my town and I hate to loose. Every time I do it costs me atleast $1000 in upgrades. This is an expensive hobby. :rolleyes:
