Battery Voltage at Idle
Old Jul 19, 2011 | 07:06 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Yeah and I'm reading off a digi-dash so those tachs aren't the most accurate.
I was under the impression that the volt-reg will go online above 15-1700 RPM.
It should hold on when RPMs drop below that around 800 or so.
This why I asked the OP to monitor voltage while throttling the engine slowly.
Old Jul 19, 2011 | 10:02 PM
hooked073's Avatar
hooked073
You are probley normal. You have to also remember the age on everything in the car. The wireing,fans,A/C clutch,injectors, ect are all drawing more amps then when new.
