Still need help with no power
Fuel pressure was checked and at 30 pounds
Cat was dropped and found it has already been cleared out
air filter is clear
fuel filter replaced
voltage was checked and at 14 volts
took to shop to put on puter and it showed said knock sensor
replaced knock sensor and pig tail today
after all the above, still have same problem.
This all started after I noticed the heater core leaking and I by passed the heater core and burped the coolong system. There wasnt a lot of anti freeze spilled on engine while by passing core. Im at a loss
I may be thinking misfire rather than bog.
can't TPS do this? no coolant splashed on it?
ideas, maybe someone can piggyback on something.
air filter is clear
