Noise in rear
Old Jul 14, 2011 | 11:31 AM
lad0050's Avatar
lad0050
2nd Gear
Default Noise in rear
I’ve recently purchased a 1995 Convertible and I’m new to the forum. I have a thumping noise in the rear of the car that sounds like driving over expansion joints. The noise stops when I apply slight pressure to the brakes, not enough to slow the car. I have replaced the rear brakes and made a visual inspection but found nothing. I’m open for suggestions.
Old Jul 14, 2011 | 11:49 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
From your description my first guess is U-joints
Old Jul 15, 2011 | 01:08 AM
Dr_Shakalu's Avatar
Dr_Shakalu
I had something like that and found out I had to replace the rear hub assembly and there was some play with the rear driver's side wheel.
Old Jul 15, 2011 | 01:28 AM
JrRifleCoach
Hey Doc! Hows your beef!?!
Old Jul 20, 2011 | 10:40 PM
lad0050's Avatar
lad0050
2nd Gear
Thanks for all of your help. I changed the drive shaft u-joints and the axle u-joints and it solved the problem.
To Noise in rear
