Dimming instrument cluster
Old Jul 15, 2011 | 09:11 PM
dewfall's Avatar
dewfall
Default Dimming instrument cluster
Hi all, for some time I've been trying to figure out what is causing my '94 LT1 to show light hesitation off idle. One thing I just noticed is that when in park, at idle, and I stab the gas quick and hard the hesitation occurs, but curiously the back lighting of the digital speedometer, fuel level, odometer also dims a bit for a split second. It's as if for a second there is lack of enough current or voltage to run everything, which makes me wonder if at idle there isn't enough power to get a strong spark with the sudden addition of fuel and air. IDEAS? Thanks!
I had the alternator tested and it was deemed okay. I also replaced the ignition coil.
