Fans not kicking on
Main fan relay on my 88 was on the driver side on the firewall, just behind the wheel but in front of the battery. Mine too was not coming on and turned out it was the main fan relay. This relay is really common throughout the car and only run about $10. If that isn't it, then the fan motor itself could be bad. You could run 12 volts directly to the fan and test it for operation.
With all that work, need to check all the electrical connections are nice and tight too. While installing other things, maybe a connection was left undone.
Is the AC ever cold? Put it on max fan, lowest temp (60 degrees) and with the doors open, the AC clutch should run almost continuously. If it doesn't get cold and cycles alot, means you are either low on freon (R12) or compressor is having issues. If low on freon, you'll have to convert it as they don't publicly sell R12 anymore.
Until the fan issue is resolved, I would NOT run the car up to 240 as you are running it dangerously close to its max limits. It would probably have to get up to 260 before it starts spilling its guts but I wouldn't push it.
But here is my issue that I had with my 95. The first fan kicks on around 180ish and the other comes on around 2 somthing. They both stoped working and I was reaching temps near 240. The issue was my relay was lose. if I remember correctly it is located near the drivers headlight. I reattached the relay and everything has been fine. I hope you find a solution to the problems. A lot of stuff seems to be breaking at once in that car.
Also make sure the fans are wired in and done correctly. sounds silly but you never know
mine is an early build Z51 so unfortunately I only have a single fan for now.......but ya it's a relay, the local Vette shop gave me a relay but it's fualty so I read them the numbers from mine and they are ordering the correct part. After installing the 160 thermostate, new fan, cooler switch,checking fuses, I was pretty stressed elctricity is soooo not my thing. I jumped the connector for the fan and let it idle for 20 minutes in 89deg day heat. Mind you the fan was continuous because of the jumper but the oil was 176 and water temp was 197 so I have high hopes it'll run cool once I get a new relay that works in place
I agree with Tony. Make sure that plate is on there. People ignore the A/C compressor a lot since they have improve DRASTICALLY since the 70's and 80's. However, they can slam the car pretty hard. Since it is almost stalling the car, I would say there is excessive drag on the serpentine belt. Start the car, A/C off, and have rev the motor while looking at your tensioner. It should flex when it revs. If it is in it's fully tight position all the time, then you have some very heavy drag on the belt. The A/C compressor itself may be bad, or the AIR that you got may be the issue.
Honestly, it does seem like the common link between all the issues is your mechanic. Try and find a Corvette shop or at least one that deals with Chevy's specifically. Stay away from dealerships!
The code that the car is throwing is probably saying that you have a cylinder missing or something along those lines. My Check Engine light comes on all the time when the motor is warm and idling in neutral. The cam just lubs the car along and the ECM gets angry. It's probably not a real problem and the car is just angry because the RPMs dropped too much.
Newbie 84:
You definately gotta keep an eye on those relays. I got so frustrated, I had my mechanic wire a bypass while he was putting in my new ZZ4 motor (I love that motor so much
). It's a constant on. I'm thinking about wiring in a manual switch, but I worry that I'll leave it off by accident.
Last edited by navy_vette; Jul 19, 2011 at 04:51 AM. Reason: forgot to say something...
Run cool!
