New CCM/BCM install question>>
Old Apr 26, 2002 | 08:35 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default New CCM/BCM install question>>
with the 1992 CCM, once you install it how many miles can you drive it before it locks you out?
I heard 100miles, but one Corvette tech at a friends Dealership said only 13-15miles.
If 13-15miles is true. Would I be able to drive with the VSS disconnected to get it programmed? if not why not?
THANKS
[Modified by -=Jeff=-, 6:36 AM 4/26/2002]
Old Apr 26, 2002 | 09:05 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: New CCM/BCM install question>> (-=Jeff=-)
Sorry I can't answer your question, but I think I may be facing replacing the CCM and wondered what brought you to change it and what was entailed?
Old Apr 26, 2002 | 09:20 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: New CCM/BCM install question>> (PTz-92-LT1)
Well long story short.. I have an 89 corvette that I just installed a 1992 Dash in... everything works.. I just need to program the CCM.. since the 89 did not have one from the factory
To New CCM/BCM install question>>
