Troubleshooting TPS for 85
Old Apr 26, 2002 | 01:27 PM
a851yy07's Avatar
a851yy07
Default Troubleshooting TPS for 85
I did a search and saw a post on about this for a 90 but is the voltage the same for an 85?
What should the voltage be at idle and WOT?
also is it A and B that i need to check?and do i need to short the computer when i check the voltage?
Old Apr 26, 2002 | 02:19 PM
JonM's Avatar
JonM
Default Re: Troubleshooting TPS for 85 (a851yy07)
Yep...A & B
Engine off
Ing. ON
.54 volts
Do not ground the ALDL
Make sure you use THREE jumper wires or back probe A & B
Old Apr 26, 2002 | 04:16 PM
a851yy07's Avatar
a851yy07
Default Re: Troubleshooting TPS for 85 (JonM)
I am getting .51 volts it looks like it is a very small adjustment to get 5.4 volts.
Old Apr 26, 2002 | 04:20 PM
scorp508's Avatar
scorp508
VERY small. Just tapping it would probably yield more than enough results. You can actually go up as high as 0.68v at idle before throwing a computer code, but 0.54 is stock.
Old Apr 26, 2002 | 04:23 PM
a851yy07's Avatar
a851yy07
Default Re: (scorp508)
actually just took a ratchet and just pryed it up a little. maybe my chugging will now be gone.
would .03 volts make that much of a differance?
[Modified by a851yy07, 3:49 PM 4/26/2002]
To Troubleshooting TPS for 85
