front spring squeak
Old Jul 23, 2011 | 11:07 PM
oldcoach422's Avatar
oldcoach422
Default front spring squeak
After pressure washing the front end of my 85 ,due to an oily power steering leak I now have a huge squeak in the front spring area. I can feel the scrapeing of the spring when the suspension is bounced. Anyone have any ideas ?
Old Jul 24, 2011 | 08:06 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
What about spraying some wd40 around the area where the rubbers are. I have the same issue on my 84. Haven't tried to stop the squeak yet.
Old Jul 24, 2011 | 05:56 PM
oldcoach422
This noise is more of a scrape than a bushing squeak, but it is going to get the silicone wd treatment monday after work Oldcoach 422
Old Jul 24, 2011 | 05:57 PM
oldcoach422
Monday it is getting a wd silicone treatment Hope it takes care of it. Oldcoach422
Old Jul 24, 2011 | 06:43 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
check the pads on the springs down where they contact the a-arms.
they may have been worn out before, you just didn't notice it due to the grease.
Old Jul 25, 2011 | 04:24 AM
vetzs's Avatar
vetzs
Don't use a silicone spray for anything under the hood, it's too easy to get to the oxygen sensor and screw it up. Use a rubber lube.
It may also be your sway bar bushings that are causing your squeak, robber lube will take care of that.
Old Jul 25, 2011 | 08:06 AM
vader86's Avatar
vader86
You probably washed away the gunk that was keepin it quiet. Sway bar bushings is something else that causes major squeak.
To front spring squeak
