96 Opti Install
Old Apr 26, 2002 | 06:46 PM
tdock's Avatar
tdock
Default 96 Opti Install
The Opti has three notches to accept the cam shaft pin, one of the notches is hour glass shaped and the other two are rectangular, I installed into the hour glass shaped one, does it matter, had the crank marking at 12:00 and the cam pin at 3:00 as you face the engine?
Old Apr 26, 2002 | 07:51 PM
greg84's Avatar
greg84
Default Re: 96 Opti Install (tdock)
hi,yes you are right on the money,i did a lot of them at work on our 96 caprices and they are a pain in the butt.good luck.greg84
