idle problems again 85 corvette
Old Jul 25, 2011 | 01:04 PM
skip myles's Avatar
skip myles
Default idle problems again 85 corvette
I replaced tps and iac checked everything by the book car run pretty good for about a week this weekend I drove to town about 15 min car sat for an hr would not idle had to keep foot on the gas to get her home I tried to crank without putting foot on gas nothing then a n hour later it cranked without giving gas but idled high about 12 to 13
thanks need help
Old Jul 25, 2011 | 01:58 PM
vette079's Avatar
vette079
Vacuum leak perhaps?
Checked for fault codes?
Checked injectors resistance as in, do they show the same numbers?
Old Jul 25, 2011 | 06:36 PM
skip myles's Avatar
skip myles
Came home today the car started fine idled 6.5 temp 192 goosed a few times went back to 6.5/6.6 still not happy thinking of pulling injection off and putting a 4bl on
Old Jul 26, 2011 | 05:06 AM
gerardvg's Avatar
gerardvg
What ... a 4bl carb= bucket with a hole ...er 4 holes
Did you disconnect the battery ? after that the ecm will need to re learn to get your engine running smooth.
The manual shows the correct iac measurement before installing it.
The tps .54vdc should start and rev to 1,200 rpm and slowly drop to
600rpm
Old Jul 26, 2011 | 08:06 AM
skip myles's Avatar
skip myles
600rpm
will recheck everything and then pull battery thursday night dont remember if i pulled the neg or not
Old Jul 28, 2011 | 12:10 PM
skip myles's Avatar
skip myles
rechecked iac and set at 450 in drive checked tps also checked for codes to start with nothing coming up pulled neg cable will run for a few days and see how it works out I also need to check vacum not sure the best place to pull from
Old Jul 28, 2011 | 01:31 PM
SunCr's Avatar
SunCr
There was a Bulletin on the '85 with a redesigned PROM as the IAC was relearning itself to 0 counts which makes it stall; difficult start etc. Dealer's were instructed to raise Min Idle to 500 rpms (or something like that). I'd get a copy of the Bulletin, check your PROM #.
Old Jul 28, 2011 | 05:25 PM
skip myles's Avatar
skip myles
ok came home tonight let car run to oper temp wants to run about 11 till temp is reached then drops down to about 8 while in park 650 when in drive I know I havent run it much to settle in the new settings wondering if this is good settings
To idle problems again 85 corvette
