85, 4+3 overdrive pressure switch
Old Jul 27, 2011 | 11:13 AM
Tcasberg1's Avatar
Tcasberg1
Default 85, 4+3 overdrive pressure switch
Should air be able to pass thru switch? I removed switch to check continuity and found that air can move from threaded side thru pin hole on opposite side. Is switch bad?
