Thoughts on cross drilled rotors
Old Jul 27, 2011 | 08:25 PM
steveo225's Avatar
steveo225
6th Gear
Default Thoughts on cross drilled rotors
I have an 88, and live in "mountainous" Pennsylvania. I notice when going down hill and getting on the brakes, the fade quickly and the heat causes them to warp slightly. They cool down just fine and work ok when just driving around town, but with 70,000 miles and 23 years of driving, I thought about upgrading them when I replace the pads.
I thought about cross drilled on the front, but wanted to get some opinions first. I have heard both good and bad about them. I found a study GM did a little back, and it found that they get about 21% more grip and about 100 degrees cooler when stopping over 120 MPH (not that I plan to do that). But, that doesn't necessarily mean anything. I figured a few people out there may have tried them out and wondered what they thought. I have also considered that standard rotors by today's standard may be much advanced and more than I need. So what do you all think?
Old Jul 27, 2011 | 08:38 PM
leesvet's Avatar
leesvet
Drilled rotors are great BUT, its all about the hole pattern.
The holes must be drilled in such a pattern so there are not any in the same vane that could crack between holes and become a weakened area that could break away. Cracking is bad enough...
Look at the patterns, and see how the holes are chamfered, that means alot. A good bevel or chamfer around the edge does lots to help the grip, disposal of debris and cooling.
The real advances have been in the pads...theres ceramics, newer composites and other late model technology that does make a difference in brake performance. Personally I like the drilled rotors and I currently run good composite pads. These are C5 brakes on a C4, much much bigger, but they work !
Just use caution withn the rotors..lots of plain cheap rotors out there with some generic hole pattern that may look good but has the fatal flaw of multiple holes in the same vane...bad deal.
Slotted are an option but most slotted rotors wear pads faster. More of a track rotor.
Old Jul 27, 2011 | 09:42 PM
cv67's Avatar
cv67
St. Jude Donor '05
Like slotted...to each their own.
Old Jul 27, 2011 | 09:56 PM
87 vette 81 big girl's Avatar
Install HAWK HPS Ferro - Carbon Brake pads front & rear.
Its best $$ lower dollar brake upgrade you can do to your C4.
They work great with the stock Corvette brake Rotors.
No break fade ever noticed by me with those brake pads on my 87 Vert.
I drive fast most of the time too.
If you have extra $$$, buy quality slotted brake rotors.
BR
Old Jul 27, 2011 | 11:10 PM
l98tpi's Avatar
l98tpi
Max G’s
Don't waste your money, they will crack. Get a good, quality pair of rotors and good shoes and gear down to utilize the braking affect from engine.
Old Jul 28, 2011 | 01:09 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Stock wheels? Are you getting enough air circulation around the brakes?
Pick a good set of rotors and Hawk pads.
Make sure your cooled off before parking and ensure you properly torque the lug nuts.
Remember to recheck torque after the first 100 miles. It will reduce rotor warp.
Old Jul 28, 2011 | 01:39 AM
mistaben's Avatar
mistaben
speaking of torqueing these wheels down..
how many ft-lbs are you suppose to use on the stock aluminum wheel - I forget again.
Old Jul 28, 2011 | 02:37 AM
JrRifleCoach
Old Jul 28, 2011 | 03:11 AM
93VettePilot's Avatar
93VettePilot
My opinion is that drilled and slotted rotors are mainly for show. They are prone to warping and cracking in daily driven cars. The small benefits in cooling does not out weigh the longevity problems.
I just threw a pair of C5 drilled and slotted rotors in the trash last month because they were so badly warped. They only had 10,000 miles on them.
As far as pads, I like the oem style ceramic pads. They stop well, last a long time, and are low dust. So you don't have to clean your wheels so often. The hawk pads are very good for performance pads but tend to dust too much and wear out fast.
Old Jul 29, 2011 | 08:01 PM
mistaben's Avatar
mistaben
Originally Posted by JrRifleCoach
100
snap. I don't think I have ever torqued them that tight.
are you suppose to tighten them down then recheck them after driving them once? thanks again
Old Jul 30, 2011 | 02:33 AM
Shock96's Avatar
Shock96
Look at the ATE Power Stop rotors. I like em.
Old Aug 1, 2011 | 10:36 AM
steveo225's Avatar
steveo225
6th Gear
Looks like this topic is a bit divided. Thanks for all the insights. I think for the time, I am just going to stick with blank rotors, they are cheaper, not prone to cracking, and I am not convinced drilled rotors are that much better.
Old Aug 1, 2011 | 12:15 PM
THE 383 admiral's Avatar
THE 383 admiral
if they are drilled correct it takes years to crack... and extreme weather like ice... when I drilled my own measuring my pattern to eliminate hitting the vanes... warping never happened....
I would go with slotted... or you could drill divots... but this will give you a popping sound from the pad creating air pockets
Old Aug 1, 2011 | 01:08 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I installed drilled/slotted rotors with my C5 conversion in 2006 and they still in good shape.
To the OP, have you consider cooling ducts?
Old Aug 1, 2011 | 01:48 PM
Aardwolf's Avatar
Aardwolf
For street cars that don't really use their brakes, they are alright. They will have more trouble with rust than blanks too.
In 3/4 of one track day I did this to a C5 set:
Get slots or whatever you like the looks of, it won't be helping performance.
My '88 FSM lists lug nut torque at 80 ft/lbs. I've used 100 without issues, with and without anti-seize.
Old Aug 1, 2011 | 03:25 PM
96_LT4_FE1's Avatar
96_LT4_FE1
I can't speak for ceramic pads, but I think Performance Friction Carbon Metallic pads might work for you.
http://www.hartsauto.com/faq.html
I've used them in the past with success, but I don't recall how much they dust. They are not quite like a "race" pad but they handle heat quite well. As a matter of fact, they some times take a bit of getting used to as they don't work well until they have a little heat in them.
One down side is they work buy depositing carbon onto your rotors which means that if you ever switch back to another pad(they don't recommend it), it will take a month or so for a regular pad to chew that carbon off the rotor.
The upside is that it turns your rotor a cool gray color.
Speaking of that, I need to order pads for my car soon...
Old Aug 1, 2011 | 07:27 PM
marcwb's Avatar
marcwb
No one has mentioned in the replies that there are, I beleive, 2 different manufacturing techniques for cross drilled rotors, cast and drilled. the cast are the most superior because in drilled rotors the metal is weakened due to the drilling. The cast is made as one peice therefore no weakening of the unit cause its made as one peice. Porches and Mercs use cast rotors and they'll wear surface material away before ever cracking.
To Thoughts on cross drilled rotors
Old Aug 1, 2011 | 07:38 PM
Aardwolf's Avatar
Aardwolf
Last I knew corner carvers had a $$$ reward for proof cast in holes even existed. Has it been cashed in? There were no cast holes that I knew of for a long time. Haven't checked into it for awhile now.
Old Aug 1, 2011 | 08:25 PM
JrRifleCoach
Always. Again, helps to keep the rotors from warping...
Old Aug 1, 2011 | 08:45 PM
Aardwolf's Avatar
Aardwolf
Pretty rare to warp a rotor. Check run out on it and see. If there were high spots there will be shiny areas like in my pictures above. Most likely there are uneven pad deposits. They will look as darker areas or whatever colored film your pads are leaving. Mine is blueish in the pix above. I commonly get uneven pad deposits during rain track events. The pedal will shudder badly. Rebedding the pads in dry conditions fixes it up.
