Alternator Installation
Old Jul 29, 2011 | 08:50 PM
myturn89's Avatar
myturn89
Default Alternator Installation
Hey everyone,
I have to put in a new alternator. The problem is that I really do not know what I am doing. I was able to remove it and get a new one. Now I am having issues with the serpentine belt. Is this a one person job? How do I get the serpentine belt onto the alternator.
THANKS!!!!!
Hopefully it will be quick and easy - with this crazy heat we are dealing with..............
Old Jul 29, 2011 | 08:51 PM
myturn89's Avatar
myturn89
Sorry I have a 1989 corvette convertible if it helps. I have the service manual but i can not find anything on serpentine belt installations.......
Old Jul 29, 2011 | 08:57 PM
yakmastermax's Avatar
yakmastermax
Have you located and created an understanding of the belt tensioner?
There might be a belt route diagram somwhere on the radiator shroud.
Do you have the new alternator mounted? There are a few brackets.
Old Jul 29, 2011 | 08:58 PM
hooked073's Avatar
hooked073
There is an automatic belt tenisoner. It has a opening for a 3/4 ratchet or braker bar. Insert the one you have and move Tenisoner to relive tenison on belt to install. It is a one person job.
Old Jul 29, 2011 | 09:16 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Yep...Mount the alternator. If there's an adjustable, slotted hole go to the outside if serp belt is older. Otherwise mount to the middle or in stationary hole as required.
Feed the belt on all pulleys except the tensioner. I use a screwdriver (if necessary to hold the belt while inserting the 3/4" ratchet/braker in the 3/4" recessed square hole. Apply pressure to compress the tensioner and slide the last loop of the belt onto the tensioner. Release and you're ready to roll!
On days where I ate my wheaties, I could depress the tensioner by hand (though it's kinda hard on the palm). And, it's a new tensioner. The original one was really easy to depress by hand.
When installed, the tensioner shouldn't have much more than a 45-deg angle up into the belt or the belt should be shortened or replaced. (I also think there's marks on the tensioner as a visual guide to belt stretch/wear.
Old Jul 29, 2011 | 09:24 PM
oldalaskaman's Avatar
oldalaskaman
Old Jul 29, 2011 | 10:19 PM
Joe B.'s Avatar
Joe B.
That's odd, my '91 uses a 1/2" drive to release the tensioner.
Old Jul 29, 2011 | 10:22 PM
oldalaskaman
tomatoes...tomaaaahtoes. use whatever works
Old Jul 29, 2011 | 10:35 PM
John A. Marker's Avatar
John A. Marker
I think it is 1/2 inch also. Insert breaker bar or ratchet and push to drivers side with one hand as you route the belt past the tensioner.
Doing this the first time is always a little awkward....but you can do it.
Old Jul 29, 2011 | 10:42 PM
GREGGPENN's Avatar
GREGGPENN
Yep. 1/2" drive is what we should have said. Alzheimers or lacking of reading comprehesion. Take your pick.
Also, with regard to the tension/stretch to which I referred, I would consider any TENSIONER sitting -- as shown in the drawing above -- worn-out/stretched/too-long. If you rotate the tensioner arm 45-deg clockwise, that's a better position for it to be sitting with the correct belt length. (IOW you'd want it pointing more at the crank pulley.)
As shown, it can/will jump/bounce and/or tap metal. You'll hear it make noise when it REALLY gets bad. Once it reaches the limit of it's travel, it taps against itself.
Edit: Though I don't have the stock alt bracket anymore, I'll still say this...IF THERE IS ANY ADJUSTMENT ON THE ALT BOLT SLOT (with an elongated slot on one of the mounting bolts), and the tensioner sits as shown in the drawing, I'd re-adjust that alt bolt so maximum slack is pulled out of the belt. That might bring the tensioner back into a better position. (I raise this option since it's available with the aftermarket accessories I'm currently running.)
Last edited by GREGGPENN; Jul 30, 2011 at 02:22 AM. Reason: TENSIONER was clarified
Old Jul 30, 2011 | 01:44 AM
yakmastermax
My '85 uses a 1/2" drive. Breaker bar makes it a snap!
Old Jul 30, 2011 | 08:07 AM
oldalaskaman
ok...six people say it takes a 1/2" ,must be true
Old Jul 30, 2011 | 08:15 AM
WW7's Avatar
WW7
More important then the breaker bar size, is making sure he reads the instructions and doesn't blow the diodes in the alternator. Ask me how I know........ WW
PS; It is 1/2"
Old Jul 30, 2011 | 08:23 AM
oldalaskaman
now yer gittin downright mean, read the directions? be still my heart.
Old Jul 30, 2011 | 08:24 AM
WW7's Avatar
WW7
Only as a last resort, "Of Course"......WW
The OP doesn't sound like he's had alot of experience with cars, so instructions are essential...
Old Jul 30, 2011 | 11:21 AM
yakmastermax
Sorry
Old Jul 30, 2011 | 12:06 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
A short cheater pipe over a 1/2" breaker bar will give you a bit more reach and leverage. The route should be on the radiator shroud. Get the belt lined up over all the pulleys and from the drivers side take tension off the pulley with your right hand and slip the belt over the alternator pulley last with your left hand.
To Alternator Installation
Old Jul 30, 2011 | 01:48 PM
hooked073's Avatar
hooked073
Yep guys I was wrong was half asleep... sorry it is 1/2 in drive
Old Jul 31, 2011 | 12:05 PM
SunCr's Avatar
SunCr
Directions would be to disconnect the Battery before you hook up the hot lead, but hopefully, it was disconnected before you took off the old alternator and the hot lead isn't flopping around the engine compartment - otherwise, have a fusible link on hand.
Tensioner should be within the alignment marks, but unless it's a new belt, that shouldn't be a problem.
Old Jul 31, 2011 | 12:43 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
