so let me start with some basic things I can do while waint for my new fuel assembly to come in. I am/was rebuilding a 383, and giving it a new intake, cam and heads. think the next step was a set of injectors?
from what I hear these Bosch 3's are the way to go? google search to find a matched set?
I want to finish this build and make this car my daily driver. can the stock exhaust manifold stay on there or does it need to be replaced too?
I thought the flow rate of the fuel pump was 255lb/hr? so that would make a max flow rate of about 32-35lbs/hr for my injectors assuming I had a BSFC of .45 - .5 or so?
am I doing the math right? so does that mean at WOT I might actually need a high-flow fuel pump?
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If you call Jon at FIC he will spec an injector and help you set the fuel flow rate in PSI.
Slap an adjustable FPR and long tube headers.
Then get some data logs and get mseven or pcmforless to burn you a chip.
You'll be amazed at the end result.
I didn't talk to jon, I talked to Bill. he came to the same numbers as me, 36lb Bosch injectors.
$369 plus 10$ for shipping. will ship tomorrow. thanks guys!
.... (now ... this guy mseven.... now how to get him to help me tune my car lol....:/ )
