In my last post i was concerned about possible bent push rods in my 87- although it turned out the ones that I suspected were probably ok. When I got to #2 exhaust it was clearly bent. I think the car was over-revved.
I checked all push rods and no others were bent. 3 did bind when spinning them. I replaced all 4 push rods and rocker arms with oem replacements.
Since all push rods were out I reset "valve lash" on all using the Chev shop manual. I used recommendations from the forum about how many turns after the push rod began to spin less freely (1/2 turn extra for new and 1/3 turn for existing).
Started car and it idles fine and accelerates normally but sounds ****** under hard acceleration. No smoke. Plugs look fine. No vacuum lines left open.
Did I miss something in setting lash? I did notice the directions seem to only talk about new push rods.
Tested compression this morning and all cylinders match what they read last fall. That should rule out a bent valve (shouldn't it?).
Anything else that I should check for while I have the valve covers off?
I'll assume from your helpful comments that the number of turns used after reaching zero lash is appropriate and that over-revving probably explains the bent push rod.
I woud have replaced the bent one and the rocker/ball. replacing all of the parts that may never fail is senseless. there are many "right" ways to do most things.
we assume the valves floated, no way to know, probably not tight valve guides.
the number of turns recommended in fsm is what I would use. In my days of building it was one full turn, and what I used. same now in my 91 fsm. not sure where the other methods came from. people who were smarter than the engineers, I reckon.
lifters should stay with the cam lobes, of course. don't know what the noise is without more info, was it being driven? what?
Reason: spell
