Where should my block learn and integrator values be ->?
Old Apr 27, 2002 | 01:14 PM
dizwiz24's Avatar
dizwiz24
Default Where should my block learn and integrator values be ->?
I got an Auto X-Ray for $175 at Summit which is right down the street from me.
Anyways, the main reason I got it was so I could monitor O2 sensor function, and fuel trim to determine if I was ever running rich (or lean, but rich has seemed to cause me more problems in the past).
Does anybody know where these numbers should be?
Where would they be if the car was running rich?
any help would be appreciated.
Thanks!
Old Apr 27, 2002 | 01:21 PM
JAKE's Avatar
JAKE
Default Re: Where should my block learn and integrator values be ->? (dizwiz24)
128 is the base reading meaning the ECM is not removing or adding fuel from that which is programmed into the PROM.
A number lower than that indicates a rich condition and the ECM is pulling out fuel, higher numbers are the opposite.
I never saw a complete breakdown on the numbers, but I did see that if yor BLMs are at 108 you'd be running about 15% rich; so I guess if you saw 148 you'd be the same amount lean.
Jake
[Modified by JAKE, 11:24 AM 4/27/2002]
Old Apr 27, 2002 | 01:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Hmm, I thought it was a little drive from Kent to the Talmadge "candy store"??
Anyway, the values should be 128 +/-6, at least for L98s.
[Modified by 65Z01, 11:31 AM 4/27/2002]
To Where should my block learn and integrator values be ->?
