ok have checked iac set at 450 tps set at .54 vacum ga 17 lbs steady had to bump timing it was at 19lbs but had a 2lb flutter bumped timing and engine smoothed out now engine runs smooth but on crank up will run 1500 rpms until 200 temp is reached then drops back to 650 it does this each time you crank it my ques. could it be a temp sensor or still timing still looking
thanks for all the help so far
